Old 09-01-2012, 04:53 PM   #1
eric28miller
eric28miller's Avatar
89 crew cab k20 4wd twin turbo cummins swap
So after months of research and purchasing parts i'm finally digging in. I first got the motor a few years back from a Case IH agriculture sprayer that i bought and stripped after it had been hit by a train. The sprayer flew 90 feet and amazingly the motor was fine, except for the oil pan, pickup tube, and injector lines. I've been wanting to drop the motor into something for a long time. I finally bought a 6" lifted 84 crew cab chevy with the frame already shortened rust free box cab and 1990 suburban power doors and front clip and 468 big block. But i ran into a big problem.. The vin tag for the dash got lost because a new surburban dash was swapped in and the old one was cut out and, well, it disappeared... Then lucky for me a different guy in town was selling his 89 crew cab chevy with 45k original miles that he bought from the Arizona swat force. He removed the bombproof swat center room whatever you wanna call it and installed a flatbed. What's great is it's never seen salt so it's in fantastic condition, inside and out. I sold the bed for $2000 and the engine for $1500 so i don't have much invested in it. Anyway i'm pretty new to these forums so bear with me as i try to get my pics uploaded and more details will come soon.
Before
After
eric28miller is offline   Reply With Quote
Old 09-01-2012, 04:54 PM   #2
eric28miller
Re: 89 crew cab k20 4wd twin turbo cummins swap
My inspiration from youtube with a 24valve.
Old 09-01-2012, 04:55 PM   #3
eric28miller
This is where i found her
Old 09-01-2012, 04:56 PM   #4
eric28miller
Old 09-01-2012, 05:01 PM   #5
eric28miller
Donor cab
Old 09-01-2012, 05:06 PM   #6
eric28miller
Finished motor!
Compound turbo kit is a massive S474 over a phatshaft 62 from industrial injection with a 3 piece manifold. I went with this kit because it's supposed to , as they told me, spool like a mother fuc**er and it looks like it would fit perfect in the c/k body with the large turbo up in front rather then down under the smaller turbo.
The whole truck will be painted chevy volt pearl white. I painted the engine red because it's cummins national color and it came from a CaseIH and it just looks awsome! I picked up the p-pump from a pullin truck that was gettin upgraded to a 13mm, so it already has all the goodies. The original AG pump wouldn't work because it didn't have an automotive governor. The old lines were mangled so i got .093 stainless lines to give it some lope. The injectors are SAC 7x14's should be plenty to fuel the turbos. I am building a little motor to connect to the manual fuel plate so i can adjust it on the fly inside the truck so it will be streetable since it will be my everyday driver. I put an adjustable timing gear on the injection pump to help tune things in easier with a custom made billet cover.
I polished all the chrome work myself, just took it to a guy i know to have it all dipped. It's very cheap if its prepped and ready to be plated. The clutch is a south bend stage 2 which will be bolted to the dodge nv4500 with a billet 1 3/8"'s input shaft and a 1st gen reman dodge 205 with extreme duty bearings and chevy outputs. I'll get pics of it up later.
As for the internals the cylinders have been bored 40 over and fitted with oversized low compression marine pistons. All new bottom end bearings and main and rods bolted together with ARP bolts and studs held together with a girdle. I sent the head out for fire ringing, 60lbs valve springs and titanium retainers and keepers.
Here you can see where the old motor mounts broke off the block when the sprayer was struck by the train, lucky for me i don't need those holes. You can see the article of the accident here: http://www.kcrg.com/news/local/3191126.html
Old 09-01-2012, 05:14 PM   #7
eric28miller
Sulastic shackles, makes a 1 ton ride like a cadillac.
Old 09-01-2012, 05:21 PM   #8
eric28miller
ladder bars
exhaust
4" turbo back to the 5" silverline stacks
rear bumper mounted
Ibeam for weight bracket for pulling
Old 09-01-2012, 05:29 PM   #9
eric28miller
stacks are not straight because they are not tightened. The will also be trimmed flush with the top of the headache rack. Batteries and washer fluid will be mounted in the toolbox.
High temp paint and heat wrapped.
King Ranch F-150 seats, not mounted yet.
roll cage
Dual Fox shocks
Old 09-01-2012, 05:29 PM   #10
82ccshorty
82ccshorty's Avatar
give me that truck please ill be your bestfriend for life
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 09-01-2012, 05:32 PM   #11
eric28miller
suspension testing : )
Homemade steering assist
crossmember
Shortened bushwacker fenderflares
That's all for now, more pics to come. Thanks, Eric
Old 09-01-2012, 05:49 PM   #12
MTCK
MTCK's Avatar
Well at this rate you should be on the road by noon tomorrow. Killer project!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-01-2012, 10:07 PM   #13
78gmc4by
78gmc4by's Avatar
This truck looks like its gonna be awesome when finished
78gmc4by is offline   Reply With Quote
Old 09-01-2012, 11:15 PM   #14
AntiGov
AntiGov's Avatar
wow lots a work....all worth it cause your gonna have a killer truck when finished......love it....
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 09-17-2012, 08:58 AM   #15
eric28miller
Used a hot pressure washer/sand blaster to strip the frame, then sprayed the frame with a rust converter, then with a rust inhibitor primer, then with gloss black urethane enamel.
While i was waiting for the frame to dry i worked on installing the 2nd gen dodge intercooler. Took a lot of trimming but it fits.
Old 09-23-2012, 02:00 AM   #16
Devillusion
Devillusion's Avatar
SICK BUILD! Pretty much exactly what I want to build.......but never will get to that point I'm sure. Nice work thus far......impressed.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 09-23-2012, 12:15 PM   #17
stepside83
stepside83's Avatar
this thing is sick, cant wait to see more, id love to this some day
stepside83 is offline   Reply With Quote
Old 09-24-2012, 09:31 AM   #18
6772owner
Gearhead
6772owner's Avatar
Love how well the intercooler fits/fills up the grille, awesome build.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-24-2012, 08:32 PM   #19
odee
did you do anything to the park-turn signal lens to fit the i/c there? build is great.
odee is offline   Reply With Quote
Old 09-25-2012, 12:22 AM   #20
eric28miller
Here's an update, installed an all aluminum 3 row radiator mounted and a dual feed fuel line for the injection pump.
Old 09-25-2012, 12:27 AM   #21
eric28miller
yea i had to cut out some of the turn signal. The intercooler goes inside the light about 2 inches. I"ll have to fiberglass the hole shut when i'm done.
Old 09-27-2012, 09:26 AM   #22
Mattman2010
Mattman2010's Avatar
This is turning out awesome. What style intercooler did you use?
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 09-28-2012, 07:12 PM   #23
V3500KING
V3500KING's Avatar
This truck will sure be sweet when its done. I am interested in how those twins sound when they spool. How many inches did those sulastic shackles add to your lift?
V3500KING is offline   Reply With Quote
Old 09-28-2012, 08:10 PM   #24
AllenMC10
This looks like it oughtta turn out good, keep at it brother, wont be long now... if you ever need any weird or odd parts, i own about 13 untitled but decent trucks, those years like that, ill sell em to ya at a super low price, or hell! Dependin' on what it is, i might give it to you, just ask, or pm me! keep postin pics
AllenMC10 is offline   Reply With Quote
Old 09-28-2012, 08:12 PM   #25
str8axle55
This truck is going to be sick, when done. Awesome work so far, engine looks amazing.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
4wd, c/k 30, crew cab, cummins swap, twin turbo
