Old 09-02-2012, 04:24 PM   #1
davecarney2
davecarney2's Avatar
1959 GMC stock engine help
I have a 1959 GMC longbed with a stock V-8. Has anyone built one up from a performance standpoint. I would like to keep the stock engine but want to build it up to about 400 horespower. Not even sure if its possible. Any suggestions, websites, etc.....???
davecarney2 is offline   Reply With Quote
Old 09-02-2012, 04:54 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1959 GMC stock engine help
If its the original engine I think you have a 336 pontiac based off the 389 pontiac so you may well find some old school hipo parts and get 300 350 hp out of it. I see pontiac tri power setups every now and then for reasonable prices.
Old 09-02-2012, 06:38 PM   #3
mr48chev
mr48chev's Avatar
It probably wouldn't hurt to check Ebay or Amazon or just Google for books or articles for souping up early Pontiac V8 engines.
400 hp might be a reach unless you figure out the right combination. that is going to take good flowing heads, the right cam and the right carb intake along with a boost in compression ratio.
A couple of examples of books to look at.
http://www.ebay.com/itm/1964-65-66-6...rature&vxp=mtr
The one I was thinking of
Amazon.com: How to Build Max Performance Pontiac... Amazon.com: How to Build Max Performance Pontiac...
Old 09-05-2012, 05:29 PM   #4
davecarney2
thank you for the input, figured 350-400 hp might be a stretch.
Old 09-05-2012, 05:44 PM   #5
Highsider
Highsider's Avatar
I test drove a '59 Chevy Panel and the stock V8 was a 283.
The owner had stuck a 4-bbl on to wake it up just for everyday street use.
Oh, and added a T400 and duals on the stock iron headers.
Highsider is offline   Reply With Quote
Old 09-05-2012, 06:16 PM   #6
Jonboy
Slots go on anything!
Since you have a Pontiac V8 and the later ones are pretty much interchangeable, why not find a 400 or 455 and make it look original? At least that way you aren't stuck trying to find a bunch of high $$$ parts to get the job done.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 09-05-2012, 08:18 PM   #7
Speedbumpauto
Speedbumpauto's Avatar
X2! A 400 will meet your HP needs easily with a few aftermarket parts and it will look the same as the engine that comes out. Most don't even know the Pontiac V-8's came in GMC's.
Speedbumpauto is offline   Reply With Quote
Old 09-05-2012, 08:38 PM   #8
mknittle
mknittle's Avatar
That is one reason I am going to run one in my 52.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-05-2012, 11:56 PM   #9
1project2many
Or boost.
There's no way to get 400hp from the tiny carb, intake, and exhaust that's found on the original engine. At that power level it's just not gonna look stock.
1project2many is offline   Reply With Quote
Old 09-06-2012, 10:42 AM   #10
Speedbumpauto
Originally Posted by 1project2many View Post
Or boost.
Point taken, but you could get there with a few hot rod parts that all of us would have loved to put on them when we were younger if we could have afforded it. Actually, it's the torque that moves a heavy vehicle like that truck and with a later 2V intake and exhaust manifolds, I'm betting it would produce near 400 ft lb of touque even if it was down a little on the higher rpm HP.....and that would really move that truck with the right trans.
Old 09-06-2012, 11:54 AM   #11
1project2many
Yep... a torque monster would be a great truck. Nice towing/ RV cam, small ports and valves for velocity, a 3.08 rear gear and an overdrive trans and you could be looking at an 18mpg+ truck that still scoots along plenty quick.
Old 09-06-2012, 12:41 PM   #12
OrrieG
OrrieG's Avatar
455, add the T/A phoenix to the hood and you are set!
