Old 09-02-2012, 05:47 PM   #1
davepl
davepl's Avatar
Need some help with carrier bearing
The replacement carrier bearing assembly I'm about to install is a little different (primarily cosmetically, I think its the right one) than the one I removed, and it's different enough from the one in the shop manual that I can't entirely rely on it to get it back in the right way. Translation: it looked simple enough when I took it apart a couple of months ago, and I should have taken better notes.
Anyway, the picture is below. My main questions are:
1) The way I've laid it out, is the carrier facing the right way? It has a steel dust shield on one side, the old one had rubber on both, so I don't know which way it should face.
2) The little "ring" in the picture... what is it and where does it go? It doesn't slide onto the splined section, at least without being seriously pressed into place. I have no idea what it actually is.
3) Am I missing any rubber seals? The shop manual mentions and shows rubber seals, but maybe they're already inside the assembled carrier?
4) Why does the end of the yoke have a screwcap on it? Just to hold grease in? Do I slide the yoke on with the cap already screwed onto the yoke, or is there more to it?
Thanks!
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-02-2012, 06:08 PM   #2
wilbilt
wilbilt's Avatar
Re: Need some help with carrier bearing
Orientation looks correct.
The "ring" in the photo is likely the grease seal that goes under the threaded cap on the yoke. The cap is there to retain the seal.
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline   Reply With Quote
Old 09-02-2012, 06:46 PM   #3
SS Tim
SS Tim's Avatar
Maybe this will help. Its from the GM parts manual but of course not application specific.
SS Tim is offline   Reply With Quote
Old 12-31-2012, 11:31 PM   #4
First c10
First c10's Avatar
I too need some help. My carrier bearing is not like the picture posted above. Mine has a clamshell style mount. Is this even stock or some kind of upgrade? Has anyone seen this before?
First c10 is offline   Reply With Quote
Old 01-01-2013, 12:04 AM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
There's two different kinds of brackets depending on if you have a coil spring vs a leaf spring setup.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-01-2013, 12:15 AM   #6
mmsidaho
mmsidaho's Avatar
Here's a pic of the stock carrier bearing on my '72 C10 with coil springs. I believe it is the "clamshell" style referenced above. I'm not familiar with the style in the original post.
1972 C20 Custom Camper
1972 C10 Under Restoration
mmsidaho is offline   Reply With Quote
Old 01-01-2013, 12:30 AM   #7
First c10
First c10's Avatar
Mine is different than your pictures. It has a big 4 bolt mount that clamshells the bearing in it with 3 bolts the hold the bearing in it. It is a lwb leaf spring truck.
I wish I would have taken pictures of it. I will tomorrow and post.
Old 01-01-2013, 11:37 AM   #8
Shyguy
Junior Member
Shyguy's Avatar
I have seen two different carrier bearings over the years, but I am no expert. One hung down and the other bolted at the bottom.
The ones I have seen bolted at the bottom were for trucks with SM-420/465 transmissions with larger diameter drive-shafts.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 01-01-2013, 12:49 PM   #9
First c10
First c10's Avatar
Has anyone used this cross member?
http://www.kplinks.com/product.php?p...8&cat=0&page=1
A couple of other threads on here show the kind of mount I have but don't really talk about it much. I have disassembled it. But will post a few pictures. Should I start a new thread?
Old 01-02-2013, 02:53 PM   #10
brad_man_72
the boat guy
brad_man_72's Avatar
Ok. Assuming that you have put the splines or slip yoke in something solid like a vice and checked for excessive hinge movement (up and down play) and your 40 year old parts are in reuseable condition.
1. Knock the metal shield off of the front driveshaft.
2. Press,beat,whatever the carrier bearing with the metal pointed to the rear of the shaft or cut the metal part off.
3. Take the press on ring and throw it in the trash.
4. The screw on cap hold in a thin washer and a cork seal. Its easier to put the cap, washer, and cork on the splines before the slip yoke.
5. Install some ujoints that don't say "precision" or "napa" on them (preferably spicer life non greaseable or neapco) shim any excessive end play, make sure all of the keepers are installed properly.
6. Reballance shaft. Seriously. I'm not kidding. Even if you marked everything and have the equipment to check the shaft for straight the new ujoints won't be exactly the same as the factory joints.
Enjoy your driveline for another 40 years.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
