Old 09-02-2012, 06:51 PM   #1
racerface
B.B. ID'ing
SCORE!!!(maybe) yesterday i got a 427 BB that came out of a C-75 chevy, early to mid 70's I was told. Problem is I need to find out if its a tall block or not and if someone could tell me the differents between the two I would greatly appreciate the help. the stamped number in the block is T0404AHT. Thanks, Pat
racerface is offline   Reply With Quote
Old 09-02-2012, 07:12 PM   #2
7dee2
7dee2's Avatar
Re: B.B. ID'ing
Pretty easy to tell with a glance. Look at the upper water pump mounting in relation to the top of the deck. Standard height is pretty close tall deck is not so. If engine is original to the C-75 you probably have a tall deck.
Good luck.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 09-02-2012, 07:17 PM   #3
wilbilt
wilbilt's Avatar
Re: B.B. ID'ing
Tonawanda plant, built April 4 1973. 427 truck engine for manual trans. 230 HP. Application: L-43 60.
Almost certainly a tall block. As I recall, the tall blocks used 4-ring pistons.
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline   Reply With Quote
Old 09-02-2012, 07:23 PM   #4
clinebarger
Re: B.B. ID'ing
On a "standard" deck BBC the water pump "legs" will be flush with the deck, On a tall deck there will be a space.
A STD deck in will have HI PERF PASS cast in the block.
A tall deck will have TRUCK cast in the block.
Standard deck
Tall deck
clinebarger is offline   Reply With Quote
Old 09-02-2012, 07:47 PM   #5
racerface
Re: B.B. ID'ing
THANK YOU GUYS!!! the guy was going to scrap the engine and I couldn't let him do it so he let me have it for a small price(far below scrap value) . now I have to ask myself what the heck to do with it?
Old 09-02-2012, 08:26 PM   #6
clinebarger
Re: B.B. ID'ing
They are worth scrap value for the forged steel crank & miscellaneous bolts & hardware. The block/heads/Intake are junk.
Old 09-02-2012, 08:40 PM   #7
davepl
davepl's Avatar
Re: B.B. ID'ing
I've never understood why these motors aren't more sought after: you'd think they'd be ideal for building a stroker motor, given the tall deck.
They're the same bore as a passenger 427 and 454. I'd think you could ditch the extra ring without problem, so a new crank rod and pistons should net you a big displacement, tall-deck big block.
Maybe they're too hard to clearance for stroker cranks?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-02-2012, 08:55 PM   #8
wilbilt
wilbilt's Avatar
Re: B.B. ID'ing
Extra ring means longer piston, hence the reason for being of a tall block. I wouldn't call it "junk", though. It is an engine designed to withstand hard duty usage.
It seems like an excellent choice for a work truck or tow rig.
Old 09-02-2012, 09:14 PM   #9
Tinkermc
Re: B.B. ID'ing
I would think value would be smal a 5.7 350 also comes 290hp
Tinkermc is offline   Reply With Quote
Old 09-02-2012, 10:51 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: B.B. ID'ing
It's not about the HP for a tll deck.They're built for torque and long life.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-02-2012, 10:54 PM   #11
69GWC
Re: B.B. ID'ing
Yeah it would be nice to know the torque numbers on one.
It would be a great motor to put in a C30 with a 4 or 5sp .
69GWC is offline   Reply With Quote
Old 09-02-2012, 11:04 PM   #12
WIDESIDE72
WIDESIDE72's Avatar
Re: B.B. ID'ing
My Dax brothers and I built a tall deck 427 for his 80 GMC c30 welding truck to replace the worn out 454 that was already bores to the max. It ran great but would not have been good for a high speed drag motor. We had to run intake spacers in order to run alow deck manifold and we had trouble finding a distributor that was long enough. We came across a lot of magnetos but few dists.
WIDESIDE72 is offline   Reply With Quote
Old 09-03-2012, 09:53 PM   #13
rollinhard
rollinhard's Avatar
Re: B.B. ID'ing
The tall deck blocks are perfect for making big inch stroker motors. My motor for my project is a tall deck 427. Getting bored out .100 and 6.7 rod, 4.25" crank netting 505 cubic inches. All the manufacturers make tall deck aluminum intakes now so no spacers required. The stock cranks in them are 3.76" forged factory gm which are the same as the big horse power 396 and they r desirable.
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
