Old 09-03-2012, 10:27 AM   #1
ffixit46
Driver window just stopped
working on a 69 GMC c10 and now i need to learn about replacing the window crank mech as the gear/crank is not working, all the tips for parts and installation would be very much appreciated.
ffixit46
ffixit46 is offline   Reply With Quote
Old 09-03-2012, 12:06 PM   #2
john
member #16
john's Avatar
Re: Driver window just stopped
heres a thread from the faq section. There are alot of good writeups in there. And welcome to the board.
http://67-72chevytrucks.com/vboard/s...d.php?t=157539
john is offline   Reply With Quote
Old 09-03-2012, 12:11 PM   #3
cdowns
cdowns's Avatar
have you tried spraying the insides real good to get the 40years of petrified grease and grung loosened up to allow the crank to move freely
Old 09-03-2012, 12:20 PM   #4
pat 70/71
pat 70/71's Avatar
Follow what cdowns recommends here, I purchased new window regulators for a truck only to find out the originals just needed a good cleaning &re lube. Cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 09-03-2012, 01:58 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If the window winder is floppy, then there is wear within the mechanism. If the handle and shaft are tight, then it probably just needs cleaned and lubed....meaning the guides and slides. If any of the guides/rollers are broken, you'll need to replace them.
But, they're not expensive and not hard to get to so you can replace them.
Member Nr. 2770
Old 09-03-2012, 02:09 PM   #6
Tinkermc
welcome to the forum, lots of good info here as you now know
Tinkermc is offline   Reply With Quote
