09-03-2012, 07:42 PM | #1 |
Lost track of idiot lights......help!
So I have my cluster torn apart and I lost track of which guage the seatbelt light goes in. Can someone please turn there ignition on and tell me which lights are in the gas guage are in the speedo. Thanks!!
Posted via Mobile Device |
09-03-2012, 08:49 PM | #2 |
Re: Lost track of idiot lights......help!
in my 81 the seat belt and brake are on the gas gauge and the 4x4 and choke lights are on the speedo
I used to be a ford man... then i learned a thing or two -81 K10 350, DD, will be mildly modified... eventually |
09-03-2012, 08:53 PM | #3 |
Easiest way to tell is to remove the bulbs and shine a flashlight through and look at the front of the cluster. It's just like lighting up a bulb in there.
09-03-2012, 09:18 PM | #4 |
I pulled the lenses out though, that's the problem. I can read the lenses just fine, I just don't know which guage gets which lens.
09-03-2012, 10:08 PM | #5 |
The lenses should only fit in one way. The little tabs that poke through them are in different places, you can't mix it up. Just did this on mine.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
09-03-2012, 10:40 PM | #6 |
Ok guys, the two lenses that go in the speedo and gas guage are the exact same dimensions, between the two is brake, fasten seat belt, 4x4 and service engine. If there was only one way everything went together I wouldn't be asking this question.......
09-03-2012, 10:43 PM | #7 |
Thank you exfordman, I'm sure my 87 is the same as yours. Probably only differences is service engine is substituted for choke. Thanks!!
09-04-2012, 09:24 PM | #8 |
I'm not trying to be a Richard Cranium, but on my 83 at least, the two little parts that protrude through the holes in the actual lens section (that say 4x4, choke, etc) were in different locations depending on the lens. My lenses could only go in one way. I wasn't trying to sound sarcastic, and I'd rather not get that back from you. I was only trying to help.
