Old 09-04-2012, 04:42 AM   #1
basshawk
Metric VS SAE Power Steering Pump
I have a metric saginaw pump off a 1985. Unfortunately I am using a short water pump and want to insure that the brackets are the same for the SAE and Metric Models. My question is: are the metric pumps identical to the SAE pumps other than the threads and hose fittings? Also does somebody have a link for alternator and psp pump brackets that will work?
basshawk is offline   Reply With Quote
Old 09-04-2012, 01:08 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Metric VS SAE Power Steering Pump
I have both laying in my garage and they are the same outside of the connection for the high pressure hose. You can even unscrew that fitting and swap it with the other style (move the spring too).
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-05-2012, 01:00 AM   #3
Captainfab
60-66 Nut
The pumps should interchange, but as Chevy Mike said, you can swap the pressure fitting. Just be careful, there is a spring inside. As for the alternator and PS brackets, what engine do you have?
Old 09-30-2012, 12:53 AM   #4
basshawk
There is a little plate that seems spring loaded behind the fitting but no spring in the fitting. Did I allready lose it? So my metric pump is the hydroboost and the third fitting hits my frame. Going to grab a non hydroboost model and swap to the metric fitting as that is what my power steering box is. will my old pulley fit? any other problems you guys can think of?
Old 09-30-2012, 06:14 PM   #5
chevy_mike
chevy_mike's Avatar
There are two pulley types, one that has a keyway and nut and the other is a press on pulley. If you get the pump with the same pulley mounting setup, then yes, your pulley will work.
Old 09-30-2012, 08:50 PM   #6
brokenspoke
brokenspoke's Avatar
one more suggestion..get a inline filter for the low pressure side....its about 1/4 inch diameter and slips inside hose....cheap insurance
brokenspoke is offline   Reply With Quote
