Old 09-04-2012, 04:50 AM   #1
76C10Stepside
76C10Stepside's Avatar
Affordable Lowering Leaf Springs for C10
I recently installed lowering shackles on my '76 C10. The 2-inch drop produced is way too little. There's still 3-1/2 inches between the tire and the fender lip. I'm running 275/60-15's on all four corners. Another 3 inches would be good.
I considered raising the front brackets 2 inches, but that would only give me another 1 inch of total drop, and installing a flip kit and notching my frame rails or removing a leaf, but after reading about suspension dynamics and leaf springs, decided lowering leaf springs is a better way to go.
Where can I get AFFORDABLE lowering leaf springs for my truck???
I've scouring the web for an affordable set of lowering leaf springs for my 76 C10 stepside. I found lots of sets for S10/S15, Jeeps and lots of Fords. The S10 springs are as low as $125-150. The only ones I've found for the C10 are these at summit racing for $426.95 (too high!):
http://www.summitracing.com/parts/WST-731014/
76C10Stepside is offline   Reply With Quote
Old 09-04-2012, 07:48 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Affordable Lowering Leaf Springs for C10
www.performanceonline.com sells drop leaf springs.
http://www.performanceonline.com/197...af-Spring-Set/
But if you want affordable,... I would just do the flip kit.
http://www.performanceonline.com/73-...p-kit-rfk7387/
Keith
Convert to disc brakes.
Old 09-04-2012, 02:52 PM   #3
69gmcc10
69gmcc10's Avatar
I vote flip kit also!
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 09-04-2012, 09:08 PM   #4
76C10Stepside
Thanks, but I do not want to do a flip kit. No time or interest in doing c-notches or in loss of load capacity and (probably) handling.
I get that C10 springs being longer than S10, would cost more, but 3-4 times as much??? Come on! Isn't there someplace that sells them for a fair price?
Old 09-04-2012, 10:05 PM   #5
Narxoleptic Customs
Just remove a few...
Narxoleptic Customs is offline   Reply With Quote
Old 09-04-2012, 10:24 PM   #6
lolife99
lolife99's Avatar
Why loss of load capacity?
Why a c-notch?
I've done at least 3 flip kits on 73-87 trucks with no c-notch.
I think a flat drop leaf spring sucks with no arch to it.
Let us know how it works out for you,...
Keith
Old 09-05-2012, 03:52 AM   #7
76C10Stepside
Yeah a friend of mine with a REAL low 56 Ford suggested that (he didn't lower his that way, tho, LOL), and I considered it. Then, I read up on how leaf springs work, and they stressed how the set of leaves are designed/built to work together, and removing leaves changes the dynamics, usually in a bad way.
Anyway, my C10 only has 3 long leaves, plus the short "base" leaf (have not actually seen that one).
From what I've read, a properly designed set of lowering leaf springs should perform well. Anybody here actually had a set on a 73-88 C10?
One the flip/c-notch: Everybody sez if I put on the flip kit, I need to notch my frame rails. Also, heard that flip kits increase axle wrap.
