Okay let me start of with the truck
74 c10 stock height 8 leaf springs in rear so it has a angle How do yall set the body lines, I want to get the line straight from front to back, is it more reliable to follow the lines on the cab, then do the front clip then the bed? My bed is 1/2-1 inch lower than the cab line on the drivers side(I was just thinking of shimming it (By body line I mean the one line that runs front to back, under the door handle) Thank for the help Frog Posted via Mobile Device |
Re: How do yall set yalls body lines?
that sounds odd
is your frame bent the fender and the front door is the tricky spot but when i put my bed on it lined right up with the cab then i moved to the rear doors on my crew, then the front doors and thats where ive stoped because the guy i bought it from wreaked it and pushed the fender into the door poping the welds and beding the door soooo i would make shure all the sheet metel underneth looks right and the bed side is bolted on you may be able to tweek it there some the problem you may run into you may have to shim that hole side of the bed then the bed will look croked from behind get a quote from a frame shop if it dont look right who knows could be a free quote and they may find something
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
Frame ain't bent, all the sheet metal and everthing looks good
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
In the past when I have been concerned with setting a horizontal line I have started at both ends, making sure they are exactly where I want them.
Next proceed by stretching a "tight" string line between these two points. Then adjust your body lines’ to match the string line, shim as needed according to the space/gap you have created at the mounts This may be more work than you wanted, but your lines will match. ![]() Good Luck |
BAD BOW-Silverado XST
Align the doors first to the cab. Next, move forward fenders, cowl, hood and bumper. You can adjust the bed with washers, leafs, and springs.
Okay well i have my cab and doors already lined up, I'm do my front end next, then use that string technique for the bed,
I want to be one of the owners with a straight lined truck Posted via Mobile Device
Gentleman Jim Driver
Normally the cab is sagged and the line is lower than the bed because of bad cab mounts. That's the first place to start with an old truck. After that it's just like Gerardo said. Doors to cab, fenders to doors, then the grill and core support and hood. The bed normally doesn't need much to line up to the cab. An inch low would tell me there is something way wrong with the frame or cab mount crossmember.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
I don't think my cab is sagging but then again I could be wrong, how would be the best way to check this, tape measure or any other special tricks, maybe measure from the ground flat level, to the body line?
How old are your cab mounts?They are just a rubber bushing when it wears out can cause the cab to sag or lean one way.
I have the same problem I think. Here is a picture from last week. The body lines are perfect on the passenger side, on the drivers side the bed looks like it sits an inch high. I took the bed off recently for frame rustproofing and did a visual on the cab mount bushings which looked fine (you can sort of see them in the other picture below. I was told on another forum that I simply have "frame twist" which is typical of these trucks, but not sure I believe it on mine which only has 30k original miles (single family owned). I'm thinking I should probably buy new cab mounts and then shim the left-rear cab mount to get the body line straight if the mounts themselves don't fix it?
1980 GMC Sierra K25, Original Family Farm Truck |
What did they say would cause the frame to twist? besides a wreck or being on an uneven surfaced road. my cab sits about half inch lower than the bed line to but i think that my cab mounts just need to be reshimed.
your post said "My bed is 1/2-1 inch lower than the cab line on the drivers side"
now that i see the pics you can most defintly tell the cab is sagging i would replace with poly cab bushings or just ship it. this is not frame twist because it dont look like its been mudding or crashed its caused by someone loving there truck and driving it by themselves alot (driver .... drivers side) i think theres 6 bushings just shimming the 3 on the drivers side or just the 2 under the cab will bring it up but shimming it ... thats alot of shims and its still a weak bushing ... hit a hard bump and the cab will jump
#13 | |
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Heres a few pictures
everything is original and looks good original bed bent dosnt look bent or twisted frame dosnt looked like nothings wrong
#15 |
well it looks like your passenger side is below the bed line where as you driver side is above the bed line. lets say that the passenger side bushing is rotted away which would explain that cab being lower than the bed line on that side, what would cause the driver side to be above the bed line, unless there are bushings that are under the bed connected to the frame that are also rotted that caused this. but i thought they did not set these beds on bushings all it is, is metal on metal or am i wrong? I am confused! if i thought correctly it looks like that frame was twisted. Unless in this pic are you on even ground or on a hill which would also explain that your frame is twisting to one side making it look like that driver side is higher than the passenger side.
#16 | |
I never thought of that, that might be the problem, i feel so dumb now, gonna check this out tomorrow( 2 days of work ![]() report with yall tomorrow
#17 | |
#18 |
#19 |
this half the price you get 4 body mounts and 2 core suport mounts there polyurithane and come with hardware
http://www.summitracing.com/parts/ENS-3-4109G/ they come in red or black and there the same price with or without hardware
#20 | |
#21 |
Dam* if only i had seen this a while ago
I dont have a credit card and borrowed a friends and bought the one's i put in the previous post, both for $40(gonna buy the other two the other check, gonna do the passenger side) A bunch of people told me about rockauto well there already paid for so nothing i can do now also bought me a 16 gallon tank, driver and passenger side gasket, 2 door strikers, 2 cab bushings came out to like $180 the first two are of the passenger side bushings and the last 3 are of the drivers side as you can see my passengers were shot and deformed drivers are used but will last me till another payday lol
#22 | |
#23 |
That was what I was thinking if doing, but let some more people put the opinions in
#24 |
yeah i agree with that one.
#25 |
i would take all the bolts out so it dont bind and bend the sheet metel but a 2x4 the lenth of the cab and lift one side at a time just lift it high enough to do the job because of the brake lines/cable and steering colom
