Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 09-04-2012, 11:49 AM   #1
RexDodge
finishing up behind the seat box
Here is a few pics of the box that we will be installing behind the seat to house a couple of 6x9's, a 10" lp sub and an amp. We designed it to have a smooth line from the lip below the window to the floor and also follow the contour of the curve in the area previously occupied by the gas tank. The side pic show the wire chase. Power will be supplied through the floor up to the amp. Signal wires will just run down the middle under the seat to the tuner in the dash. We plan to cover it with the same material being used on the door panels (marine naugahyde in matte black). I will post up some completed pics once we have it installed.
RexDodge is offline   Reply With Quote
Old 09-04-2012, 10:11 PM   #2
Gonepostal
Gonepostal's Avatar
Re: finishing up behind the seat box
very nice need one for mine
Gonepostal is offline   Reply With Quote
Old 09-22-2012, 02:48 AM   #3
RexDodge
Pyle 1600w amp, 2 Sony 6X9 speakers, 10" Alpine type E sub, 2 5" up front in the stock location under the dash with a Kenwood reciever (usb aux with blue tooth). Sounds good. Putting the seat in tomorrow for the final tune. I will cover it next month with a marine naugahyde (matte black).
Old 10-19-2012, 10:47 AM   #4
blazer2007
How do you secure the box in ?
blazer2007 is offline   Reply With Quote
Old 10-19-2012, 01:18 PM   #5
jimmydean
jimmydean's Avatar
That looks real nice! I need to build mine, but I have so many other projects that need attention...
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-23-2012, 11:23 AM   #6
RexDodge
@ blazer2007, We drilled holes at the points where the cab mounting bolts come up through the floor. I just installed longer bolts and used large diameter washers.
Old 10-23-2012, 11:24 AM   #7
RexDodge
Right there with you. So many projects...and they have nothing to do with the truck!
