Old 09-06-2012, 04:37 PM   #1
blackbear
Arrow lowering blocks
does anybody know the measurments to fab rear lowering blocks. how wide; how long; where to drill holes and what size to drill. any info would be great.
blackbear is offline   Reply With Quote
Old 09-06-2012, 08:33 PM   #2
dougf
dougf's Avatar
Re: lowering blocks
Originally Posted by blackbear View Post
i like to find some measurments to make a set of rear lowering blocks. length;width;what size of holes to drill and how far apart to drill them. any info would be a great help.
Let me do a little research, I just saw a thread about a week ago on lowering blocks on the cheap, let me see if I can dig it up for you...
dougf is offline   Reply With Quote
Old 09-06-2012, 08:39 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: lowering blocks
7" long block.
2" wide.
7/8" holes on 4.25" centers.
Keith
Convert to disc brakes.
Old 09-06-2012, 08:39 PM   #4
dougf
dougf's Avatar
Re: lowering blocks
This thread is for 60-72 lowering: http://67-72chevytrucks.com/vboard/s...d.php?t=454824
Ahh, here it is! http://67-72chevytrucks.com/vboard/s...d.php?t=196457
Home made blocks from fence post, I would contact him for more info. Good luck!
Old 09-06-2012, 11:01 PM   #5
blackbear
Re: lowering blocks
thanks guys for the info.
Old 09-06-2012, 11:02 PM   #6
blackbear
Re: lowering blocks
Old 09-07-2012, 11:52 PM   #7
rbar
rbar's Avatar
Re: lowering blocks
I could measure mine in a couple of days, but I can tell you right now that it's pretty much the width of the trailing arm mount point, the same center to center pattern of the u bolt, and for length I'd make it to the end of the trailing arm, and then the same distance on the other side (front) of the block. Then the thickness is generally 2" or whatever you want it to be.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 09-08-2012, 06:42 AM   #8
dougf
dougf's Avatar
Re: lowering blocks
This thread should give you all you need, good luck! http://67-72chevytrucks.com/vboard/s...d.php?t=541867
