Old 09-08-2012, 03:24 PM   #1
SRVBLUES64
ticking noise
Ive had this ticking noise since I finished the eingine, now I know that the valves are lashed but not sure correctly now has for an exhaust leak my headers are bolts are tight maybe my flange bolts ar not tight it does not have a gasket umh any thoughts
SRVBLUES64 is offline   Reply With Quote
Old 09-08-2012, 05:22 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: ticking noise
It could be a couple of things. A valve not adjusted enough. You may want to re-check them. Take a long screwdriver and put the handle to your ear and the tip on the valve cover. Move it around and see if your tick gets louder. If you find one, it may be a valve that needs readjusting.
As you say, it may be an exahust leak. I had a header leak that drove me crazy once. I replaced the gasket and problem was solved.
Hope that helps.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-08-2012, 05:28 PM   #3
Indian113
Indian113's Avatar
Re: ticking noise
Just a thought,is your dipstick touching the crank?
Indian113 is offline   Reply With Quote
Old 09-08-2012, 06:17 PM   #4
awbrown
Re: ticking noise
The best way to find engine noises is with the poor mans stethescope.. it is a 3 ft length of rubber hose 3/8 to 5/8 works fine ... with the engine running hold one end to your ear and drag the other end all over the area you think the noise is till you pin point it .. to check rocker arm noises pull the cover and work the hose around all the valve train till you find it ....messy but very effective....
awbrown is offline   Reply With Quote
Old 09-08-2012, 07:01 PM   #5
63burban
Chevy addict
Re: ticking noise
It's possible that the spring on the fuel pump is broke, that one can drive you nuts.
63burban is offline   Reply With Quote
