Old 09-08-2012, 07:36 PM   #1
mikentiff
Converting 8 lug to 5 lug
I have a 72 GMC c20 2wd is there a kit out there that will convert the front and rear to 5 lug ?
mikentiff is offline   Reply With Quote
Old 09-08-2012, 07:47 PM   #2
mr48chev
mr48chev's Avatar
Re: Converting 8 lug to 5 lug
NO not one that you can just swap a few piece and go.
The best suggestion I have is to find a hall ton driver quality truck or parts truck with both the front and rear suspension under it and swap the complete front and rear suspension both ways and sell the doner truck. I thought about dong that with my 71 GMC but stayed with the 8 lug as I use the truck to haul and tow too much and just picked up a camper from the same era to match it.
Old 09-08-2012, 08:19 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
ECE makes a C20 to C10 conversion spindle.
This make the front as easy as swapping spindles and adding C10 rotors and calipers.
A 71-72 rearend would be the easiest swap for the rear.
Is your C20 rearend coil spring or leaf spring?
Keith
Convert to disc brakes.
Old 09-08-2012, 08:36 PM   #4
desertnick69
desertnick69's Avatar
Why do you need to change them? It's a C-20!
desertnick69 is offline   Reply With Quote
Old 09-08-2012, 09:12 PM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
Don't mess with a C/20!!!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 09-08-2012, 11:24 PM   #6
desertnick69
Not messin with C/20 (got two myself) Why they got to put 6 & 5 lug on them?? (Nice truck Sicklajoie)
Old 09-09-2012, 08:37 AM   #7
mikentiff
It is leaf spring.......I want to convert it to disc brakes and lower it a little and it would look awful lowered with nive wheels the way the axle comes past the tire......unless you guys know something I do not!!!!!
Old 09-09-2012, 09:00 AM   #8
lolife99
lolife99's Avatar
There is a few lowered C20 threads.
Here is one:
http://67-72chevytrucks.com/vboard/s...78#post4761778
If you use Google to search,... you will be surprised how many searches end up right here on this board.
Keith
