Old 09-08-2012, 11:49 PM   #701
Kim57
Kim57's Avatar
Re: My 57 Pro Street
Originally Posted by spousta View Post
Where did you get your hydraulic system from, I need to do something similar with my bed setup
I got it from these guys.
http://www.hopposonline.com/
Saw them at the Pomona swap meet.
Real nice guys.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-19-2012, 08:11 PM   #702
shadow1967
shadow1967's Avatar
Kim,
Could I get a pic of the front drivers side, with the header on, shot down the frme rail to see the clearance between the flange and frame rail? And one shot stand over the front wheel looking toward the motor? i'm having clearance issues with the 2 pair I already have. I really don't want to buy 2 more. If this one didn't work.
Thanks,
Mike
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 09-20-2012, 12:17 AM   #703
Kim57
Kim57's Avatar
Mike
I've got the frame all apart for cleaning and painting right now.
I do have this one shot of the header on the drivers side.
I know it's not the best. I was checking steering shaft clearance.
The other is without the header but gives a little idea of the clearance.
I had decent clearance from the header flange to the frame on the drivers side.
I did have to notch the frame on the passenger side. I think they moved the tubes out to keep them away from the starter.
I centered my engine between the frame rails.
I hope it helps.
Kim
My build thread
Old 09-22-2012, 02:51 PM   #704
Kiowa317
Great truck!
1979 Chevrolet k10
1958 Chevrolet apache 3100
Kiowa317 is offline   Reply With Quote
Old 09-22-2012, 06:51 PM   #705
Kim57
Kim57's Avatar
Originally Posted by Kiowa317 View Post
Great truck!
Thanks for looking.
Kim
My build thread
Old 09-22-2012, 07:19 PM   #706
Chevette
Chevette's Avatar
Kim: When are you painting the frame and what coating are you going to use? Also, what color? I'm going with an epoxy primer and two part urethane top coat in semi-gloss black. Thought I'd make it look like late model factory.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 09-22-2012, 11:28 PM   #707
Kim57
Kim57's Avatar
Right now I'm thinking of using Rustoleum primer and then the Rustoleum Hammered black top coat.
I think it will hide some of the imperfections in the frame and should be fairly durable and easy to touch up if I have to make any changes down the road.
Kim
My build thread
Old 09-23-2012, 12:06 AM   #708
Chevette
Chevette's Avatar
Kim
"Imperfections", in your frame? I don't think so. Anyway, I saw a hammer finish on a frame (I think it was on the internet somewhere) and it looked great.
56 Chevy PU
Old 09-23-2012, 12:08 AM   #709
sgtusmc
sgtusmc's Avatar
Great job Kim! Truck is looking great. I painted the wheels on my Tacoma with the black hammered Rustoleum a few years ago. No chips so far, and they get plenty of offroad time.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 10-02-2012, 06:38 PM   #710
renegade8720
Kim,
Nice pro street!
What size flange bearings did you use for your pivot mount for the bed on your truck?
Renegade
renegade8720 is offline   Reply With Quote
Old 10-02-2012, 08:52 PM   #711
mknittle
mknittle's Avatar
Kim
I like the hammered black. I am thinking about painting my rally wheels as well as my frame.
I painted the stove hood in our kitchen hammered silver on the inside and black on the outside. that stuff is pretty tough!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-02-2012, 09:46 PM   #712
Kim57
Kim57's Avatar
Originally Posted by renegade8720 View Post
Kim,
Nice pro street!
Renegade
Thanks for the compliment.
Here's a pic of the bearing. The hole the in it is 3/4"
Kim
My build thread
Old 10-02-2012, 09:47 PM   #713
Kim57
Kim57's Avatar
I've painted a couple of small parts and like the way it looks.
I haven't thought about it for my wheels though. I may have to try that.
Kim
My build thread
Old 10-03-2012, 09:50 AM   #714
mknittle
mknittle's Avatar
Kim
I used a couple pillow block bearings that were mounted vertical with the same size bearing to make a speed reducer for my industrail sewing machine. Could be usefull to mount on top of a crossmember.
Mark
My GMC build.
Old 10-16-2012, 11:19 AM   #715
Chevette
Chevette's Avatar
I'm eagerly awaiting a great looking painted frame............................ Anything to report?
56 Chevy PU
Old 10-16-2012, 06:16 PM   #716
Kim57
Kim57's Avatar
I finally got all the rust off and some metal prep on it to keep it from rusting again.
Now I just have to figure out how to hang the frame in the garage so I can paint it without to much trouble.
Kim
My build thread
Old 10-16-2012, 11:24 PM   #717
oldman3
oldman3's Avatar
With all the neat stuff you have made, I know hanging your frame is no problem...Jim
oldman3 is offline   Reply With Quote
Old 10-17-2012, 09:51 PM   #718
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Truck is looking great......
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 10-17-2012, 09:53 PM   #719
Kim57
Kim57's Avatar
Thanks.
Kim
My build thread
Old 11-15-2012, 03:26 PM   #720
Kim57
Kim57's Avatar
Well I finally made a little progress on the truck.
Got the frame cleaned then primed and the first coat of paint on it.
I used Rustoleum "Hammered Black" in a quart can which really looks like a very dark grey when it is applied.
This kind of annoyed me as I used a rattle can on some of the small parts and it is a little darker.
The other thing that is annoying is the window for a second coat. If you don't get it on in under 4 hours you need to wait 7 days because of the way this stuff dries.
It looks O.K. in the pics but definitely needs another coat.
Kim
My build thread
Old 11-15-2012, 03:30 PM   #721
Kim57
Kim57's Avatar
I also detailed the engine. I used some cast aluminum paint on the heads and block and a light blue metallic on the intake rocker covers and pan.
Kim
My build thread
Old 11-15-2012, 03:48 PM   #722
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: My 57 Pro Street
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 11-15-2012, 03:52 PM   #723
hotrod1
56 - autocross
hotrod1's Avatar
Hey Kim:
That looks great! What paints did u use for the engine? Rattle can, make, and color?
I like the frame finish as well. Did it come out the way you expected it and would u do it again if given the chance to do it over? Make sure to give us close up pictures of the frame when the pain is complete.
hotrod1 is offline   Reply With Quote
Old 11-15-2012, 04:34 PM   #724
Kim57
Kim57's Avatar
Originally Posted by 1Bad62Pro/Street View Post
Thanks.
Originally Posted by hotrod1 View Post
Hey Kim:
Thanks.
The paint is VHT rattle can engine enamel.
I used "Cast Aluminum" on the block and metallic "Titanium Silver Blue" on the intake covers and pan.
The frame for the most part looks the way I want it too.
I did some research on the net and ended up using a good bristle brush to apply it as it has to go on thick to get the hammered effect. I cleaned the brush constantly while applying it as it would start to dry and be kind of a pain.
You also have to constantly stir the paint or it separates fairly quickly and you can get a color difference.
As far as doing it again I'll let you know when I get the second coat on in a week or so.
Here's a close up of the frame. You can see it needs another coat.
Hope this helps.
Kim
My build thread
Old 11-15-2012, 04:39 PM   #725
hotrod1
56 - autocross
hotrod1's Avatar
Thanks.
Thanks.
Hope this helps.
Kim
Nice, thanks!
