Old 09-09-2012, 10:03 AM   #51
Southern Shaker
Re: Maybellene 52 gmc
Originally Posted by mknittle View Post
it all started about 15 years ago when I painted this and for payment I got the GMC.
Thats a Beautiful Pete!!!
Southern Shaker is offline   Reply With Quote
Old 09-09-2012, 11:00 AM   #52
mknittle
mknittle's Avatar
Thanks, it is a working truck and brakes down les than a lot of the newer ones. But like out smaller trucks it is constantly upgraded
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-11-2012, 07:22 PM   #53
mknittle
mknittle's Avatar
after i got as far as i wanted {for now} to on the suspention i decided to fix the cab floor before my tubing became somthing else for the second time
mr 48chevy was kind enough to post the stock dementions for the front cab mounts.
So Idid some measuring and shimming to get the cab wehr it is supposed to be. then I made a simple frame out of scrap 1" square tubing that used holes that were already in the cab. At the bottom of each leg I welded a piece of angle iron witha hole and anut welded toit for adjustment. On the lower lege I tacked a short piece of .5 tube to the seam at the bottom of the toe board.
Mark
My GMC build.
Old 09-11-2012, 08:15 PM   #54
mknittle
mknittle's Avatar
now the floor from the seat riser to the toe board could be cut out.I marked and cut about a 1/2 inch in front of the seat riser and just inside the rocker panel flanges then stright down at the floor were it meets the toe board.
next I cut out the cab mounts out.
the floor at the rocker panelstuerned out to be a bit tougher than I thought at first, it turned out that the guy at the factory ran two to three spot welds together. So drilling wouldnt work.I ended up useing a 1/8" wide cutoff wheel
but first I used the 4" sander at a 45degree angle on the 90degree brake where the molding goes for the windlace.
Mark
My GMC build.
Old 11-08-2012, 11:24 PM   #55
Chevette
Chevette's Avatar
Haven't seen a post for a while. You getting anything done? BTW that Pontiac looks good.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 11-08-2012, 11:53 PM   #56
mknittle
mknittle's Avatar
Yeah I just have been lazy in posting.i will try to do some catching up in the mornings while i wait for the sun to come up.
I have a soft spot for those old pontiacs
Mark
My GMC build.
Old 06-10-2013, 03:44 PM   #57
_Ogre
_Ogre's Avatar
yawn... see mknittle's post above from last yr
shop air compressor timer
Old 06-11-2013, 08:44 AM   #58
mknittle
mknittle's Avatar
OK I will try to get some pics up this afternoon
Mark
My GMC build.
Old 06-11-2013, 08:46 AM   #59
mknittle
mknittle's Avatar
I have been meaning to post some but life got in the way
Mark
My GMC build.
Old 08-03-2014, 08:19 AM   #60
msaintg
msaintg's Avatar
another year, no posts
msaintg is offline   Reply With Quote
Old 11-17-2014, 11:01 PM   #61
lower50's
lower50's's Avatar
Looks like a cool build. Any more progress?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
