Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 09-09-2012, 02:07 PM   #1
ecgate
ecgate's Avatar
Where to buy Blasting Media?
Just got a blasting cabinet and was wondering what type of media is the best to use. And who sells media?
ecgate is offline   Reply With Quote
Old 09-09-2012, 03:06 PM   #2
Snowbound
Snowbound's Avatar
Re: Where to buy Blasting Media?
Check out Eastwood's web site.
I bought mine at Princess Auto, which is the Canadian version of Harbour Freight. They have all different types and it depends what you are blasting.
I'm doing mostly steel brackets, etc and picked up the Aluminum Oxide. It is supposed to last longer and no silica to worry about!
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 09-09-2012, 03:14 PM   #3
blacklistcustoms
blacklistcustoms's Avatar
check a local rock quarry or batch plant, they usually have 40lb bags of sand for cheap usually_cheers
66 c-10 swb stepside -my daily driver
74 1Ton CrewCab Shortbed 4X4
(2) 91 2500 suburban 4X4
91 K5 Blazer 4X4-wifes daily driver
73 K5 Blazer 4x4- project soon to be 2wd
50 3 window 3100
blacklistcustoms is offline   Reply With Quote
Old 09-09-2012, 05:26 PM   #4
McCoyAZ
McCoyAZ's Avatar
100 pound sack of silica sand is 10 dollars at True Value
Big warning on the bag though that says DONT USE FOR SAND BLASTING, but i never follow directions well.
McCoyAZ is offline   Reply With Quote
Old 09-09-2012, 06:31 PM   #5
Indian113
Indian113's Avatar
That's because it cause's a disease called "Silicosis" You need a damn good resperiator. If you damage your lungs it's ireversible you can't be cured. It would take a New set of Lungs to fix the problem
Indian113 is offline   Reply With Quote
Old 09-09-2012, 07:08 PM   #6
McCoyAZ
McCoyAZ's Avatar
yes dear. :-)
I do have a damn good resperator and I also use it very very carefully in fully ventilated work station.
But I do use it for media blasting because it works well.
Old 09-09-2012, 07:15 PM   #7
hugger6933
Check into some plastic, it is supposed to last a long timeand the dust is way down, not a huge deal in a cabinet but some so that you can see in the window.
hugger6933 is offline   Reply With Quote
Old 09-09-2012, 07:15 PM   #8
Indian113
Indian113's Avatar
Now that we have that settled,I use Black slag. I buy it at Northern Hydraulics
I wear a mask when I put new silica sand in my pool filter!!
Old 09-09-2012, 07:54 PM   #9
ecgate
ecgate's Avatar
Does anybody use that Black Diamond media that TSC sells? It is supposed to be low free silica and low in dust. On top of that it is only $8 for a 50lb bag.
Old 09-09-2012, 08:48 PM   #10
cdowns
cdowns's Avatar
i dont like using sand in my cabinet cause it is very dusty makin seeing what i'm blasting dificult add to that it does not stay sharp long // i use a carbide based black stuff that i found from a local supplier i found by googeling it up on the computer// have used very similar stuff from harbor frieght but thier price was hi and it did not last that long // 100lbs of that black stuff cost me about $80 but i can do well over a hundred manifolds and loads of brackets and wheels and it still cuts good i usually get new stuff every 18months or so
i've never needed to use a respirator when using my cabinet as i have a hiquality well sealed unit with an excellent exhaust systen and i get no fumes or dust in the shop area
Old 09-09-2012, 09:41 PM   #11
LooseCannon
this is what i've used for years. works great.
LooseCannon is offline   Reply With Quote
