Old 09-09-2012, 09:48 PM   #1
bigd65
bigd65's Avatar
Inside firewall insulation
What else can be used besides the one that is in LMC and such, that seems a high just for some insulation
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 09-11-2012, 10:23 AM   #2
Lone_Star
Re: Inside firewall insulation
Well, I ran across this issue while working on another project car. I used a suggestion from another forum where you use the high density foam that is used for cheap camping mats from Wally world as the insulation, then glue on an oil absorbing mat found at OReilly auto. I used the original to make a template, cut and glued the two pieces together, then glued it to the firewall. It worked well and does keep the noise down from the engine compartment.
Lone_Star is offline   Reply With Quote
Old 09-11-2012, 11:04 AM   #3
SS317
SS317's Avatar
What about that peel and seal stuff from home depot? Would that work very well for this application?
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
