09-10-2012, 03:01 PM | #1 |
Parking brake driving me nuts!
I can't get the parking brake to hold my truck on even the slightest incline. My brakes and all the components are in great condition, I adjusted them so they slightly drag, I adjusted the parking brake pedal so its solid at about 1/3rd the way down and they still won't hold. Everything behind the drum operates smoothly. I lubed the park brake cable and it all operates as it should but it still won't hold my truck even on flat ground. I have worked on plenty of brakes but this has me pulling my face off! Any ideas?
http://smg.photobucket.com/albums/v655/aaronhero/ |
09-10-2012, 03:19 PM | #2 |
Re: Parking brake driving me nuts!
Assume you checked for brake fluid or oil soaked shoes and glazing. How about shoes in the correct location (primary VS secondary)?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-10-2012, 03:26 PM | #3 | |
09-10-2012, 04:07 PM | #4 |
Are the shoes adjusted correctly? Is the cable tight when the parking brake pedal is hard, 1/3 the way down? If it is tight and no oil or glazing on the shoes or drums I would get out the shop manual and make sure all components are installed in the right location, orientation, etc. Something is a miss.
09-10-2012, 04:21 PM | #5 |
rear cable in the cable housing rusted in place and not moving anything inside the brake drums is the rule rather than the exception
09-10-2012, 04:32 PM | #6 | |
09-10-2012, 04:38 PM | #7 | |
09-10-2012, 05:01 PM | #8 |
Are the drums new or turned? If you turned the drums and the shoes were not arced you may have too a small contact area. While this may be workable with the service brakes the park brake may not generate enough pressure. This would be especially true if you are parked on an uphill grade trying to keep the truck from rolling backwards without the benefit of the self energizer. If this sounds like it might be the problem pull a drum and a shoe to verify the fit. Full contact is desirable and a high glazed spot would be worse case. Might also want to verify inside diameter of the drums as well. Also are you using a brake setting gage or guessing? Have you tried adjusting the rears off the ground in neutral?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
09-10-2012, 05:09 PM | #9 | |
09-10-2012, 06:00 PM | #10 |
Im now trying to ID my axle, I know it's a 12 bolt but the parts store wants more info in order to get the correct seals and bearings. First off this is a 72 GMC K1500 4X4, I found three sets of numbers, the first is on the upper left side of the diff housing, it reads "CN2". The next set is on the rear left axle tube which reads "1234", the 4 is questionable. The last set is on the lower left side of the diff and reads "678", the 6 in this case is also questionable.
The parts guy asked if the seal has a locking ring on it, I don't want to pull the axles until I have the parts as this is my daily driver. He's tellingly there are 7 different options as to what seals and bearings I may have. Anyone have any idea what axle I have? Posted via Mobile Device
09-11-2012, 01:30 AM | #11 |
Moderator
Aaron- Here are the seals you will need
National (Federal Mogul) part number is 8835S. They measure 1.618 x 2.575 x 0.460
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-11-2012, 10:56 AM | #12 | |
I guess I will find out in a little while when I tear into the rear end. I'm replacing the bearings as well so I hope I got the correct ones otherwise my truck will be sitting on jack stands until tomorrow. Thanks! Posted via Mobile Device
09-11-2012, 10:59 AM | #13 |
Moderator
I also have a 72 12 bolt rear end. These were the seals I used. Yours should be the same. Good luck, this is definitely the reason your e-brake is not working!
09-11-2012, 11:03 AM | #14 | |
09-11-2012, 11:05 AM | #15 | |
09-11-2012, 11:25 AM | #16 |
Same ones I used about a month ago.
09-11-2012, 04:43 PM | #17 | |
The bearings that were in there looked like they were the originals, they had a snap ring on the inner and outer race that held the bearing cage in place. They were very, very pitted so I'm kinda glad I had problems with my brakes or I wouldnt have noticed how destroyed the bearings were. Any of you guys ever used these "repair bearings"? Do they work? I went ahead and bought new pads, the others had some very large cracks in them and were filled with gear oil. Brakes on, now I just have to wait till tomorrow morning to get the new bearings. Good excuse to exersize the 69 for a couple days! Thanks again! Aaron Posted via Mobile Device
09-11-2012, 11:20 PM | #18 |
Almost forgot, while I was pulling the old bearings I saw this strange item fall to the ground under the bed, I don't know where it fell from exactly but it landed in front of the rear axle. I was surprised anything could be under there cause I took the bed off the truck when I painted it, I don't know how I could have missed this thing. Anyway it's about 1 1/2" long with about a 5/8" hex head. It has very fine spiral threads from the very tip to the base of the hex head. I can't figure out what it is, I doubt it's part of the truck. Looks like a tool. Any ideas?
Posted via Mobile Device Posted via Mobile Device
09-12-2012, 03:56 PM | #19 |
Got my new bearings this morning, the "repair bearings" and they worked great. I doubt I will ever have an issue with oil getting on the brakes now, the new bearings have two seals, one inner and one outer seal. It took a while to polish the new wear area on the axles but it was sure cheaper than a pair of new axles. Best of all I have a parking brake now and my brakes work better than ever.
Thanks again for the help! Aaron P.S. anyone have any idea what the thing is in the above photo? Posted via Mobile Device
09-12-2012, 04:22 PM | #20 |
I can't see the pic, but based on your description it sounds like the shaft of a gear puller.
09-12-2012, 04:31 PM | #21 | |
09-12-2012, 05:17 PM | #22 |
Now that my brakes are all pretty and new I am wondering exactly what the procedure is to activate the auto adjusting mechanism. I've always thought you need to back up and jam on the brakes to get it to turn the star wheel, then I have been told they adjust (if needed) every time you use the parking brake. Anyone have the straight poop on how they really work?
My brakes work better than ever now that I fixed the leaky seals. It's amazing how much damage so little gear oil can cause, the pads on the leaky side were cracked all over, deep cracks that went all the way through the pads. I'm guessing they were getting pretty hot even though they were soaked with oil. Posted via Mobile Device
09-12-2012, 05:41 PM | #23 |
Looked it up in my '70 factory manual. It covers all 10-30 series trucks with the standard Duo-Servo brakes that I am pretty sure continued through '72.
"Brake shoe adjustment takes place when brakes are applied with a firm pedal effort while the vehicle is backing. Applying the brake moves an actuator which turns the star wheel and lengthens the adjuster screw assembly (fig.2)."
09-12-2012, 06:31 PM | #24 | |
09-12-2012, 07:24 PM | #25 |
20' Daredevil (Ret)
Also (I found out the hard way) with the brakes assembled, you should reach through the slots in the backing plates -- with the brake tool -- and turn the star adjusters until the brakes start to drag. Then back them off a few turns. That gets 'em close, and they'll fine tune themselves as you back up & apply the brakes.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
