Old 09-11-2012, 02:21 PM   #1
petes
Need some help?
I'M proud owner of -70 long bed stepside, 307, 3-Speed manual.
My wipers and turnsingnals stop working same time? Is there connection whit those? Or is it just loose wires? Fuses seems to be ok.
Thanks advance!
petes is offline   Reply With Quote
Old 09-11-2012, 03:55 PM   #2
Wrenchbender Ret
Re: Need some help?
Check the connections on the back of the ign. switch. Sometimes the wires &/or switch terms. get burnt. There is a pigtail connector available for that.
Wrenchbender Ret is offline   Reply With Quote
Old 09-11-2012, 04:55 PM   #3
petes
Re: Need some help?
Ok I look for that.
**** hart to put this in English words.
When I got the truck I did left ingnition key allways to 10'a clock position.
Over night batery died. Then I realise that at 12'a clock postinon power stays?
I haven't find out what cauce or what use power on that 10' clock position?
Don't have radio, lights where off...
You get any of what I try to say
Old 09-11-2012, 07:24 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: Need some help?
Yes. Think we understood. I would bet a nickle on the ignition switch being bad or the wiring as wrenchbender mentioned. On our trucks the switch should be straight up when the key is off. If yours has accessory that would be the 10 o'clock position.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-11-2012, 09:45 PM   #5
Tinkermc
Re: Need some help?
I think you have the two first choices and a safe bet 1 or the other
Tinkermc is offline   Reply With Quote
Old 09-12-2012, 02:13 AM   #6
petes
Re: Need some help?
Ok thanks!
Will look those!
I come back some other problems later
Old 09-12-2012, 06:01 AM   #7
petes
Re: Need some help?
Here is few pictures of my truck!
Old 09-12-2012, 09:39 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: Need some help?
Now that is one nice, clean looking truck!!! Did you find over there?
By the way, welcome to the site. Lots of people here that can help if you have other problems. And, let us know what you find with your electrical problem. Also, if you look in the electrical section, there's a lot of wiring diagrams to look at or download.
06 Trailblazer
Old 09-12-2012, 09:52 AM   #9
Pizzalovr36
Re: Need some help?
just to let youknow thats a 69 innr grill
Pizzalovr36 is offline   Reply With Quote
Old 09-12-2012, 12:51 PM   #10
petes
Re: Need some help?
Thanks for well coming and for that 69 grill.
It have come over here 2004 from US but can't remeber where. I did bought it a few months a go. So have'n get to know it so well. It have had some restoration over here. Like paint job. What you say about color is it anything close to original GM color. Former owner told that it might be from VW color map??
Old 09-12-2012, 01:09 PM   #11
68gmsee
Active Member
68gmsee's Avatar
Re: Need some help?
Not sure about the color but I like it. Similar to dark blue green #512.
The 69 and 70 inner grills were identical except for the color scheme. Only trained eyes can detect it. And as you found out they're here...
Look at pics below.
06 Trailblazer
Old 09-12-2012, 01:20 PM   #12
petes
Re: Need some help?
Yeah right big differense..
Color look that dk green poly...
Thanks!
I Will ad some more pictures as I get home. Out of town right now.
