09-12-2012, 01:45 AM | #351 |
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
Thanks man, I will keep it up. Im ready for this thing to be running, Ive had a lot of motivation for some reason recently but there is nothing wrong with that!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
09-12-2012, 02:34 AM | #352 |
6>8 Plugless........
Nice work on the wheel repair.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
09-12-2012, 09:40 AM | #353 |
Thanks bud.
09-12-2012, 11:08 PM | #354 |
Chevy Enthusiast
Those tires look pretty beefy back there! I hope you plan on getting steel spacers for it, I would get 2" so you have room to grow...
BTW that wasn't a wallowed out hole, the older budd wheels have the oval hole like that. All of mine were like that and it was fun finding 6 new valve stems like that while in town one day. Good job on closing it up though, I came real close to doing that to mine.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
09-12-2012, 11:41 PM | #355 | |
As for the wallowed out hole I am 100% sure that it was wallowed out. For some reason that wheel has a good amount of rust around that area. You can tell something had rubbed on the edges because they where not flat, they tapered to kind of a point on the inside. All my other wheels have a standard size truck valve stem that uses a 5/8 hole on the wheel. Posted via Mobile Device
09-12-2012, 11:49 PM | #356 |
Chevy Enthusiast
That wheel was rusted real bad because of water setting in between it and the tube for (who knows how many years) and they put a tube in it because they couldn't find any of those style valve stems. Ask me how I know...
09-13-2012, 12:01 AM | #357 | |
Well fine mr. Smarty pants just playing man. It makes sense but all my other wheels have the standard 5/8s valve stem so idk, maybe that wheel is older or something, I know that the truck sat with that tube in it for 10 years or so. Need to find me some 16.5s! Posted via Mobile Device
09-27-2012, 09:48 AM | #358 |
This is what it is looking like with 285/75/r16s on the rear and 33x12.5s on the front. I have decided that I am going to box the front part of the frame to the back of the cab. I am doing this because at some point I plan on having more hp and tq so by doing so it will cause less tear on the frame and I have also noticed that the frame does flex quite a bit the way it is. I am not off roading with this truck so limiting the frame movement will not really hurt the truck in any sort of way.
09-27-2012, 10:04 AM | #359 |
Good idea, it's looking good!
09-30-2012, 08:50 PM | #360 |
Well I have a somewhat small update. Oh wait, I mean a big update. Met up with Ryan (DieselWrencher) and finally picked up my motor and trasnfercase. I also got a cracked NV4500 from him that he is letting me borrow it so I can get the mounts made and then I will go get the good transmission from him later.
CUMMINS! NV4500 and NP205 Still have to find a bell housing for the transmission. I did get an adapter plate from ryan also but we are not 100% sure if it will work or not.
09-30-2012, 09:49 PM | #361 |
Chevy Enthusiast
Sweet!
09-30-2012, 10:45 PM | #362 |
Chevy Enthusiast
What intercooler /radiator /fan do you plan on using?
09-30-2012, 11:21 PM | #363 |
Good question! I have no clue! Opinions? haha I am planning on getting a new 4 core bb radiator and running 2 electric fans.
09-30-2012, 11:58 PM | #364 |
Chevy Enthusiast
I'm not real sure in the intercooler but I think i'm gonna use one from a powerstroke, like this I guess: http://www.ebay.com/itm/7-3-powerstr...add61f&vxp=mtr
Ryan will know what fits. A chevy 4 core should be good but I'd try to squeeze a mechanical fan in there first and use electric fans as a last resort.
10-01-2012, 12:02 AM | #365 |
I think he said that the dodge mechanical fan would not fit on this because it was out of a freightliner, and their fans wont fit into a regular truck.
10-01-2012, 12:38 AM | #366 |
Chevy Enthusiast
How far apart are those bolts on the front pulley, will a chevy fan fit on it?
10-01-2012, 12:44 AM | #367 |
dont know, have not really looked into it lol
10-02-2012, 09:23 PM | #368 |
you can always get a dodge fan bearing off ebay or something so you can run the dodge fan. I have one from a 92-93 intercooled dodge as they were a little bit shorter, and gave more room for the fan. they are hard to find though usually.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
10-02-2012, 10:48 PM | #369 |
I was told that I would have to get all the dodge brackets for that to work because it moves the belt closer to the motor so all the brackets would have to change.
10-04-2012, 10:18 AM | #370 |
Well I picked up some steel monday that was scrap to use to box the frame. Itsf6 pieces of 10" by 5 ft 1/4 in steel. Should be strong enough.
Last night with the help of a couple buddies and my dad we were able to get the cab off of the frame so that i can box the frame easier. Just gotta move some stuff around in the shop and push the frame back in.
10-05-2012, 09:41 PM | #371 |
Started boxing the frame tonight. First peices are going slow trying to get the hang of it.
10-08-2012, 04:23 AM | #372 |
That's looking good so far!
10-09-2012, 12:53 AM | #373 |
Thanks man!
As for an update I should have some pictures some time this week with all of the frame boxing pieces all in place. I replaced the front cross member because all the cummins conversions I have seen on these you have to cut the cross member, so I just cut it out and put a new one up toward the front of the frame. Ill be using 4x4x1/4 inch tubing for the cross member for the motor so I dont see a problem with having the front cross member mounted in the very front of the frame.
10-12-2012, 02:32 PM | #374 | |
Nice progress and keep it up man!
10-21-2012, 08:35 PM | #375 |
Things have been busy with school so things have not been going as fast as I was hoping but I did get some shop time today.
Got the sleeves for the steering box and got them welded to the frame. Still need to drill out the boxing plate to fit around the sleeves. Also made a new cross member for the front because the stock one has to be cut up to fit the 12v in so I decided to make a new cross member so that I can try to mount the motor lower in the frame some. Got more plates tacked in the frame. Getting close! That is all for this update. Hoping to get the frame done the next time I get to work on the truck. Then it will be time to put the cab back on and start making the mounts for the motor.
