Old 10-12-2003, 10:47 PM   #1
crackajacka
Stylin
crackajacka's Avatar
Question abandon plug identification help???
ok does anyone know where these plugs goto? do i need to wire them up a certain way?
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 10-12-2003, 10:48 PM   #2
crackajacka
Stylin
#2 i belive these are the cruise control plugs but im not sure they go threw the firewall just below the fuse box.
thanks for the help
Paul
Old 10-12-2003, 10:51 PM   #3
gldevall
gldevall's Avatar
I believe #1 is for the stock carb.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 10-12-2003, 11:20 PM   #4
1FaastC10
1FaastC10's Avatar
close, #1 is for the ESC and TCC lockup. #2 is a plug for the cruise control, as suspected.
1FaastC10 is offline   Reply With Quote
Old 10-12-2003, 11:25 PM   #5
crackajacka
Stylin
tcc? torque converter lock up? how do i go about hooking that back up?
Old 10-13-2003, 12:32 AM   #6
1FaastC10
1FaastC10's Avatar
http://www.73-87.com/garage/lockup.htm
Mike's site comes in handy quite often...
Old 10-13-2003, 01:14 AM   #7
crackajacka
Stylin
if mike looks at this post then maybe he has some advice on hooking up from the connectors my trans is a th350 thanks for the link i might go ahead and swap to a 700r4, but im stuck with my th350 for awhile
Old 10-13-2003, 02:28 PM   #8
swervin ervin
You get what you pay for
swervin ervin's Avatar
I think the read plug is supposed to go to the EGR bleed solenoid. That was the thing mounted the very back passenger side valve cover. It's got something to do with tranny lockup. When I took all this mess off my truck, I had to rewire my tranny like I have it on my site.
As for wiring up a TH350C to lockup, I've never done it. I'm not sure what pressure switch you need in the valve body. It may be the same one used in the 2004R's and 700R4's.
The big hose for the cruise goes to the brake switch under the dash. It's the same switch that unlocks the tranny when you press the brake pedal. This is what kicks the cruise out when you press the brake.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 10-13-2003, 09:57 PM   #9
mhorning
mhorning's Avatar
Mike
I've been following this post and you got me to thinking. I have the same plug on my truck just dangling. The truck originally came with a 700R transmission, but the stock 305 motor was replaced with a 350 and headers. Does this mean there is something not hooked up correctly? Any suggestions on how I can tell. As far as I can tell the transmission shifts correctly.
Mike
63 Chevy C10
86 Chevy K10
mhorning is offline   Reply With Quote
Old 10-13-2003, 10:07 PM   #10
swervin ervin
I don't think it has to be plugged up to the solenoid in order for the tranny to shift right. My 700R4 didn't lock up when I got my truck. I checked everything I could find and never got it to work with the stock wiring. The article I have on my site I found in a magazine and decided to wire mine this way. Well, there is a gagle of wiring on the stock setup, including the wiring going to the EGR bleed solenoid. Only thing I ever found out about it is of course it has something to do with when the EGR works according to tranny lockup. I figure it's either it works only in fourth or doesn't, or something to this effect. I believe the tranny sends a signal to the solenoid and thus to the EGR.
I just got tired of messing with mine and am glad I did away with all this crap. Our trucks had way too much wiring on them, IMO. I guess it was a shotty way for GM to try and get good emissions on these things. The gov was after them hard to improve on this stuff right about then.
Old 10-13-2003, 10:14 PM   #11
Slonaker
Insert Witty Text Here
Slonaker's Avatar
If you are talking about the red plug in the first photo, this is what mine looked like before I disconnected everything. I have not hooked it back up yet.
If you can figure out what it is, my vacuum diagram is posted in ocbaud's post asking what can be disconnected from his emission controls. See here.
It screws to a stalk theat bolts to the second to the last intake bolt on the passenger side. The little black thing it plugs into has two vacuum hoses going to it. I don't know what it is or how it works.
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-13-2003, 10:18 PM   #12
swervin ervin
That black thing is the EGR bleed solenoid. The wiring going to it is connected to the tranny wiring. If you remove this wiring, the tranny will no longer lockup.
Old 10-13-2003, 10:27 PM   #13
Slonaker
Slonaker's Avatar
If your post was directed at me, Swervin, I am hooking everything back up. I just did a cam change, and I am cleaning and repainting everything as I put it back together. It is taking way to long...
Slonaker
Stock '01 Silverado
Old 10-13-2003, 10:47 PM   #14
1FaastC10
1FaastC10's Avatar
slonaker, did you ever get your AIR setup figured out?
Old 10-14-2003, 12:26 AM   #15
Slonaker
Slonaker's Avatar
No, that's why I am trying to talk ocbaud out of any useable smog parts he pulls off his truck. Texas has not yet announced when they will start testing in my county, other than to say "soon," so I haven't made a priority of it yet.
The same offer goes for you, too. If your truck had the same emission controls as mine, I'll pay shipping on any salvageable parts you remove. Ocbaud's thread on desmogging has a list of what I'm looking for...
Slonaker
Stock '01 Silverado
Old 10-14-2003, 12:26 AM   #16
crackajacka
Stylin
my trans shifts ok with out it hooked to anything and was ok cept it would shift to third and then u could hear it speed back up, i guess it locks up then unlocks i dont know.
Old 10-14-2003, 12:29 AM   #17
Slonaker
Slonaker's Avatar
When it locks up, it will feel like a light shift. You have to be expecting it for it to be noticeable. I'm told that it is easiest to tell if it locks up if you have a tach.
Slonaker
Stock '01 Silverado
Old 10-14-2003, 12:31 AM   #18
crackajacka
Stylin
well since the b***** shifts 2 third at 25 then when it gets to 35 or so it rev's up noticiably
