Closed Thread
Old 09-12-2012, 11:19 PM   #4851
Square_78
Square_78's Avatar
Re: What did you do to your truck today!
Replaced my spark plugs, cap, rotor and wires, checked vacuum and timing.. truck is still missing under load. runs great, normally around town but as soon as you put it to the floor, it starts missing and hesitating. Could it be the points? How do you know when your points need to be replace? fuel filter is also new.. This old stuff is all new to me. Frustrating. I cant wait for my LMC order to show up with all my interior bits. Then I will be happy again!
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline
Old 09-13-2012, 08:35 AM   #4852
Shyguy
Junior Member
Shyguy's Avatar
My son and I finally got back on the '67 swb stepper we are building for me to use in the last week. It had been setting in my garage since last fall when we moved the cab from the lwb frame to the swb frame and transferred all the '71 5 lug running gear to the frame.
We are building this as nice driver with a few mods here and there to make it what I like, which may not appeal to others. Since I plan to drive it and not sell it, I figured what the heck might as make it the way I like.
In the last week we ground down all the repair welds in the cab, pressure washed the frame and cab, primered the floor, installed a power brake booster and yesterday he shot gloss black paint on the frame, fire-wall and floor of the cab.
We are letting the paint dry for a few days and then we are going to prep the inside of the cab for priming and painting.
My son is the motivator on this project since he has rebuilt quite a few of these old truck, I am providing the finances and doing as much as I can to help.
Some day with what I have learned from my son I hope to do a project myself, only time will tell how that works out since I am getting to be an old guy.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 09-13-2012, 04:52 PM   #4853
yuccales
yuccales's Avatar
Went through a box of stuff that came with the truck and found this Royce cb/am/fm radio. I had to do it. It works! While it's not like my 29LTD, it does get out a bit. Kinda a cool old radio. Best part, no dash cutting needed.
yuccales is offline
Old 09-13-2012, 05:43 PM   #4854
69GWC
Wow that's pretty cool, nice find.
69GWC is offline
Old 09-13-2012, 05:58 PM   #4855
PAWS 72
PAWS 72's Avatar
Dang I know that I'm going to install mine now.That looks good.
PAWS 72 is offline
Old 09-13-2012, 09:38 PM   #4856
weever82
weever82's Avatar
I flushed the radiator and took her for a spin... getting ready for winter season. In AZ thats prime time for car shows!
weever82 is offline
Old 09-13-2012, 09:39 PM   #4857
weever82
weever82's Avatar
Originally Posted by Hard Luck View Post
Lets see..Installed and removed 9 headers...still trying to find a set that fits.
Shortys - 69648 - Fits 67-72 C20-C30 but not C10, kicks out to the side too much and hit frame, collector is in "C" channel, not ideal
Tri-Y's - no part number - Fit beautiful on the driver's side, pass side only hit;
1. frame
2. Brake Line
3. Starter
4. Cross Member
5. Lower A-Arm
6. Trans Cooler Lines
and the outlet points toward the flex plate cover
Mid Length - 68600 - fits Camaros and Chevelle - both front tubes hit upper engine stand offs, pass side a bit worse
Full Length - 69890 - Fits 67-87 C10- Pass side fits but hangs about 4" under frame, could not even get driver's side installed with almost everything removed
The copper colored ones are what I started with and the set that is going back in.
Hedman has a new Mid Length - 69016 - that no one stocks yet but they tell me they used an actual truck for fitment. The pass side looks good but the driver's side looks like it might drop a bit too soon. We'll see, if I can find a set.
Let me know what works for you! my 69 C10 has some full length Hookers and my passenger side rubs every now and then... drives me nuts.
Weev-
weever82 is offline
Old 09-13-2012, 09:42 PM   #4858
71tahoe
71tahoe's Avatar
Originally Posted by 71tahoe View Post
Have you tried a full length from a 69 Camaro? Had some on a 69 with 350 but using I6 motor mounts. Tucked pretty nicely.
Cyclone from 71 C10 on left, from 69 Camaro on right.
71tahoe is offline
Old 09-13-2012, 11:07 PM   #4859
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
On the way to "Mountain Muffler", Bass Lake, CA.
Only "broke" three things on the way.
The "Brothers" one-size fits all (67-72 stainless) gas cap does not. Gas blew all over the side of the truck.
The master cyl I painted this morning leaked brake fluid all over the new paint.
Grabbed a hand full of parking brake...Too much. A clamp under the dash let loose. Smacked me pretty good
and broke off the brake handle "cover" that bolts to the bottom of the dash.
The de-bugging phase. This part's all been on the trailer.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-14-2012, 12:05 AM   #4860
mud.man.rj
mud.man.rj's Avatar
Even on the trailer...that's one good lookin truck.
mud.man.rj is offline
Old 09-14-2012, 12:18 AM   #4861
HotRod C/10
HotRod C/10's Avatar
what size is that rear tire.......looks BEEFY!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline
Old 09-14-2012, 12:28 AM   #4862
magwakeenercew2jh
275/45/20 On 10" wide 338's. Because of the backspacing (not to re-start anything ),
I'm running 1" spacers...maybe 1.25" to clear the bed (width-wise). I can't really remember which width spacers.
To mud.man.rj....Thanks very much. I appreciate the thumbs-up. Three years solo and a little help with the heavy lifting
from a couple of good pals. Glad to be at the (sometimes frustrating) "de-bugging" stage.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-14-2012, 01:02 AM   #4863
jayman68
Fun Stuff
jayman68's Avatar
1. frame
2. Brake Line
3. Starter
4. Cross Member
5. Lower A-Arm
Here are some you might want to check out. Good luck in finding the right fit.
http://67-72chevytrucks.com/vboard/s...d.php?t=314836
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline
Old 09-14-2012, 10:58 AM   #4864
beerman
Early this morning we hooked it up to a gooseneck trailer and went to get hay. We put 22 rolls of hay on that trailer and the 72 pulled it like a champ. I love that truck I want 5 more just like it lol.
beerman is offline
Old 09-14-2012, 02:56 PM   #4865
street_rodder
street_rodder's Avatar
Location: The World's Most Famous Beach...Daytona Beach, FL
Installed all new "lighted markers and new Brothers 68 GMC front turn signal lenses... ( Beware that these DO NOT come with new gaskets like their catalog says)...luckily my gaskets were in very good condition...
Today....new power steering hose...blew a hole thru the old one while truck was sitting, parked....for no apparent reason!!
street_rodder is offline
Old 09-15-2012, 08:12 AM   #4866
Billett
Billett's Avatar
Found out my rear main leak is a rear main and an oil pan leak, my rear shock mounts are shot, my upper coil mount was missing, my trans has no reverse lights ran to it, my new exhaust was ran where my bump stops used to be and apparently I've been driving around for four months with no pilot bearing. On the upside it's Saturday
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline
Old 09-15-2012, 10:09 AM   #4867
VWNate1
VWNate1's Avatar
Post Re : What did you do with your truck today!
Typical Summer in La La Land ;
It's been over 100° F so instead of driving my air conditioned Mercedes , I've been driving my '69 C/10 . it starts right up and goes just fine in the blistering heat , but of course ! it's an 42 year old unrestored CHEVROLET .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 09-15-2012, 10:47 AM   #4868
magwakeenercew2jh
Ouch!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-15-2012, 04:01 PM   #4869
VDOG
Grand PooBaa Member
VDOG's Avatar
As good as that GMC grill looks, im still debating on changing my GMC to the 67-68 chevy front grill. Still not sure.
VDOG is offline
Old 09-15-2012, 04:44 PM   #4870
DevilDog Aggie
DevilDog Aggie's Avatar
She's legal!!!! Woohoo!!!
Rob
'72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC
Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187
Semper Fi and Gig'em Aggies!
DevilDog Aggie is offline
Old 09-15-2012, 05:41 PM   #4871
Steve Hafner
Steve Hafner's Avatar
We took it out to a local show and enjoyed the beautiful 75* weather.
Talked to the owner of a 71 with an ORIGINAL 307 valve cover decal.
Steve Hafner is offline
Old 09-15-2012, 07:08 PM   #4872
shopking72
shopking72's Avatar
Drove it up to a weekly Friday night car show
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline
Old 09-16-2012, 11:55 PM   #4873
ksucatz
Suppose to be workin........
ksucatz's Avatar
Started the engine swap...got the old one out!!
Think there was a small oil leak.....somewhere.....
Stay tuned
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
"Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown
ksucatz is offline
Old 09-17-2012, 12:59 AM   #4874
PAWS 72
PAWS 72's Avatar
Put her back in the shop after having a ruff weekend. Had to carry the wife to hospital Thursday,she had some medication that caused problems.the truck had to spend the nite in the parking lot whick I didn't like to well, brought her home Saturday morning then she got treated to a nite on the town.we all loved it.
I've got to clean it up for a show I'm doing this weekend.She is going to show off a little.haha.
wish me well fellows there will be about 20 in this groupif it's like last year.
PAWS 72 is offline
Old 09-17-2012, 01:06 AM   #4875
magwakeenercew2jh
I'd say you already won...Glad she's okay.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Closed Thread
