Old 09-13-2012, 06:46 PM   #1
Xeen
Xeen's Avatar
GM Tilt column Questions
I found a GM Truck tilt but the tilt joint has some slop is that a bad bearing or is it possible the bearing collar is just loose?
The guy is asking $300 for it even with the slop.
If the column needs to be rebuilt how much is it worth as a core I need to know how much to offer.
Thanks in advance.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-13-2012, 07:15 PM   #2
davepl
davepl's Avatar
Re: GM Tilt column Questions
What's a rebuild kit worth? I'm going to rebuild my non-tilt one (after 100,000 miles and 40 years I think any of them should be checked), and I imagine its no difference in price for the rebuild.
I don't think "new" ones are available, unless you want an aftermarket one. But if your cost for the core plus the rebuild comes to the same or less than an Ididit, you're probably at a fair price.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-13-2012, 07:39 PM   #3
fakerwade
fakerwade's Avatar
Sometimes the 4 bolts holding the upper part of the column become loose, easy fix after you remove the pivot pins.
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 09-13-2012, 08:53 PM   #4
jaros44sr
jaros44sr's Avatar
There is a bearing retainer and nut that could of come loose on the upper most bearing, although it would be hard to tell if this is the case, unless you would be disassembling it
Would be nice to know if the tilt knuckle was reprod...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
