Old 09-17-2012, 07:42 PM   #1
Harpie
Harpie's Avatar
Rearend question
Ok so pulled the rearend out of my parts truck. It's a 12 bolt posi the old man I got it from thought it was a 373 but it did not say that on the spid. So it being a 350 auto truck c10 I figured 3.07 so before I took it out I did the ol mark the tire and turn it and count how many turns it takes to make one rotation. It was 3 1/4 with would be 3.55 so does this sound correct? I guess I just need to crack it open and take a look.
Harpie is offline   Reply With Quote
Old 09-17-2012, 08:02 PM   #2
SS Tim
SS Tim's Avatar
Re: Rearend question
Showing 3.07 as the standard ratio for that powertrain with 3.73 or 4.11 as optional. Probably a 3.07. If it is loose pulling the cover, inspecting and cleaning is always a good idea.
SS Tim is offline   Reply With Quote
Old 09-17-2012, 08:37 PM   #3
Harpie
Harpie's Avatar
That's what I figured it was but I will get it cleaned up and tear it all down and take a look got a set of 3.73s for it since I'll be running a 4L80E hate for it to be a dog in overdrive. And thank ya sir for the reply always enjoy your post.
Old 09-17-2012, 10:14 PM   #4
DesertCat
DesertCat's Avatar
Hang on a sec... if it is indeed a 3.07 Eaton unit the 3.73's won't work in it unless they are Richmond gears meant to be used in the 3 series posi.
3.73 and numerically higher use a 4 series posi unit. You might want to look into that before unpacking your new gears. Good luck!
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
