Old 09-18-2012, 11:03 AM   #1
ubtripn
ubtripn's Avatar
Where to start with over-steer??
Hi Folks,
I just replaced the shocks, tie-rod ends, idler arm, installed power-steering and put new, stock sized tires and rims on my 68 with an alignment and I still have a squirrly, over-steer problem.
Should I install a sway bar?
Could it be that I have the power-steering with the faster ratio (for lack of knowing the right term.)
I just don't know where to begin. She drives straight and I installed new upper and lower ball joints so I don't know what to do.
Thx for any advice.
ubtripn is offline   Reply With Quote
Old 09-18-2012, 11:31 AM   #2
CC69Rat
CC69Rat's Avatar
Re: Where to start with over-steer??
So it feels like a dump truck when you turn? The truck wants to go straight and the wheels want to turn?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 09-18-2012, 11:35 AM   #3
ubtripn
ubtripn's Avatar
Yeah, kind of, it leans heavily and just moving the steering wheel a couple of inches gets way too much response.
Old 09-18-2012, 11:42 AM   #4
mr48chev
mr48chev's Avatar
What did they set the caster at? Years ago when I did front end work and alignments for a living I found that not enough caster on some vehicles caused a condition similar to what you are experiencing and although the vehicle drove great at slow speeds it was twitchy and too sensitive to the slightest touch on the steering wheel.
If it takes off on it's own when the road surface changes you might still have something loose in the front end or steering.
Old 09-18-2012, 11:57 AM   #5
Boog
laying low
Boog's Avatar
This condition is common when going from non power steering to power steering. It takes some getting used to. I remember many years ago I put a power steering setup on a friends 1 ton ramp truck. He said on a couple of turns he nearly ran up on the curbside. He was so used to having to put so much effort into the old setup it took some getting used to the new one requiring less effort. Also the gear ratio in the standard and power sectors do differ some.
Now if it's a matter of the truck leaning too much on turns a sway bar will most definately help that. Just a front one is very noticeable.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-18-2012, 12:05 PM   #6
ubtripn
ubtripn's Avatar
Thanks friends, I will check the castor and get on installing a sway bar asap. Thanks again.
Old 09-18-2012, 12:09 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Post up some pics of your tie rod assembly.
Keith
Convert to disc brakes.
Old 09-18-2012, 12:44 PM   #8
ubtripn
ubtripn's Avatar
Ok, will do, it will be a little while. Thanks for the help =)
Old 09-18-2012, 12:56 PM   #9
airdale94
airdale94's Avatar
Did you get a printout of the actual adjusted readings? If so what are they?
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 09-18-2012, 02:01 PM   #10
CC69Rat
CC69Rat's Avatar
Is it worse turning one direction vs another? Radial tires I guess or when you say 'stock' are you rrferring to bias ply?..
Does the truck sit level side to side? If something is wrong or possibly loose it could be dangerous to drive (?) It may not be to that extreme.. but, just thinking out loud.
Chad
