Old 09-18-2012, 09:10 PM   #1
67mater
67mater's Avatar
DIVORCED NP205 passenger side drop transfer case
HARD TO FIND divorced passenger side drop np205 transfer case, Make anything 4wd!!! no slop, ready to run. the np205 is BULLETPROOF and this one can be mounted as far back as you like (with a mid shaft), behind any 2wd transmission. Perfect for you r 4wd project with lots of lift, since it let you run a longer front drive shaft with less pinion angle. Also perfect if you want to run a 2wd overdrive trans and cant afford the crazy cost to mate a 205 to a overdrive directly.
$350 or best offer. trade for first gen camaro parts
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 09-28-2012, 08:41 PM   #2
67mater
67mater's Avatar
Re: DIVORCED NP205 passenger side drop transfer case
$300 obo
1967 K10
1967 Camaro
Old 09-29-2012, 10:23 AM   #3
MoreLoveThanMoney
MoreLoveThanMoney's Avatar
Are you willing to ship it?
MoreLoveThanMoney is offline   Reply With Quote
Old 09-29-2012, 10:45 AM   #4
67mater
67mater's Avatar
It's stupid heavy. Fed Ex freight might take it as is (open) if you were ok with that. Otherwise it needs crated. No idea what cost would be to ship like that. Only other idea I have is if you check out Uship.com and see if anyone is going that way would do it. Or I can see if I can find somethign to haul back and we could work somethign out
1967 K10
1967 Camaro
Old 09-29-2012, 10:54 AM   #5
67mater
67mater's Avatar
at a conservative 150# and freight class 70, Fedex freight wants $400 (I played with weight and size and economy was still $400). best bet is to find someone going that way
1967 K10
1967 Camaro
Old 09-29-2012, 05:10 PM   #6
MoreLoveThanMoney
From what I can tell shipping ups or fedex would be around $100. Do you have the shifter and linkage?
Old 09-29-2012, 05:40 PM   #7
67mater
67mater's Avatar
that's only if it's under 150 lbs. 24" x 16" x12" and even 155 lbs is $500 fed ex 3 day freight. what you see is what you get
1967 K10
1967 Camaro
Old 09-29-2012, 05:47 PM   #8
67mater
67mater's Avatar
it's 144 lbs which is $112 to 73105. I need to figure out if it has to be in a box/crate (maybe you want it in a box) and if I can do that and stay under 150 lbs
1967 K10
1967 Camaro
Old 10-02-2012, 08:47 PM   #9
67mater
67mater's Avatar
Sold
1967 K10
1967 Camaro
