Closed Thread
Old 09-17-2012, 11:55 PM   #6126
DoubleL
DoubleL's Avatar
Re: What did you do to your truck today?
Today I replaced my heater fan. I'm going to be needing that soon! Also
figured out my door locks. Narrowed it down to one key that fits the ignition and both doors even though one of the handles isn't the original!
DoubleL is offline
Old 09-18-2012, 12:45 AM   #6127
markeb01
Senior Enthusiast
markeb01's Avatar
Slid under the back of the truck and cleaned/polished the chrome rear end cover and the brake lines on the axle housing.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 09-18-2012, 09:36 AM   #6128
LT1 Burb
LT1 Burb's Avatar
Dropped off the rear end to get rebuilt and another load of parts for the powder coaters.
LT1 Burb is offline
Old 09-18-2012, 09:40 AM   #6129
coulter
coulter's Avatar
Originally Posted by Goldie80 View Post
Installed my offy intake, headers and carbs Saturday.
thats badass
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline
Old 09-18-2012, 09:40 PM   #6130
dantimdad
dantimdad's Avatar
Coil spring clamp kit came in from Eckler's today. Only thing left to get for the rear suspension is shocks and bolts and stainless button heads for the diff cover.
Gettin' excited now!
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 09-19-2012, 12:43 AM   #6131
woodscavenger
woodscavenger's Avatar
Went to DMV, got the title started and got temporary registration! Hah, I'm finally on the road!
I see I am not the only one that pretend drives. If you look at my blog on my other project you should get a good laugh out it. My wife did.
http://47ihc.blogspot.com
woodscavenger is offline
Old 09-20-2012, 11:45 AM   #6132
russellmalcolm
russellmalcolm's Avatar
Today I tackled the tank job I have been waiting to do; with some help from this forum I found out that my filler hose was cracked, I could feel it with my fingers. So, took out the tank and started the work (thanks to markeb01 for the trouble shooting suggestions).
Name:  tank in truck.jpg
Name:  tank out of truck.jpg
Name:  truck without tank02.jpg
Name:  truck without tank.jpg
Russell
1966 GMC Truck Project
http://67-72chevytrucks.com/vboard/s...26#post5602826
russellmalcolm is offline
Old 09-20-2012, 01:32 PM   #6133
ChuckW
ChuckW's Avatar
I see a small light at the end of this tunnel..... Sanding party this weekend on the bed sides..... Hope to have a driver end of Oct.?????
ChuckW is offline
Old 09-20-2012, 01:46 PM   #6134
glos55
glos55's Avatar
Sweet!!! Your truck is coming along great!!!!!
LIFE IS SHORT HAVE FUN
glos55 is offline
Old 09-20-2012, 01:48 PM   #6135
glos55
glos55's Avatar
Had new exhaust installed
glos55 is offline
Old 09-20-2012, 02:11 PM   #6136
Narxoleptic Customs
Mounted my final 2 Titan 18" sPares, pix soon.
Narxoleptic Customs is offline
Old 09-20-2012, 04:15 PM   #6137
BenkeBird
BenkeBird's Avatar
I adjuste the emergencybrake cable and take a ride to wisit a friend
BenkeBird is offline
Old 09-20-2012, 06:21 PM   #6138
CRGRS 66
CRGRS 66's Avatar
Yesterday actually, drove my truck to work. I am in sales, so kinda drove it here and there all day, love the oohs and aahs from my clients!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 09-20-2012, 07:52 PM   #6139
r3skyline
Just received my 21 Circuit Rebel Wire kit, so im going to be having fun tearing into the wiring from now until I go back to work MON.
r3skyline is offline
Old 09-20-2012, 09:53 PM   #6140
pmkrew
Compiled and cleaned a bunch of engine parts after a 3 year haitus things were scattered here and there. Short block's been together for about a year and now I'm just a timing chain and oil pump shaft away from having it ready to finish re-assembling. I hope to have engine finished and transmission ready to go on my off days next week...
pmkrew is offline
Old 09-20-2012, 10:04 PM   #6141
awbrown
Drove 'ol blue to church in the evening and as I got home I pulled up to the garage door and thought I would see if I had high beams,I knew I had low beams ... Turned out I had NO beams .. so I started checking it out, had power out of the dimmer on both sides when tested high and low .. so checked at the 2 wire bulkhead by the horn and had nothing .. got out my small sandblaster with the spot nozzle on it and blasted the corrosion off the terminals at the firewall and dimmer .. finally got them working and noticed the wire was hot to the dimmer switch ... Checked the bulbs and sure enough they were halogen ...lucky when I installed the relay for the radiator fan I installed a row of 3 from an 88 sierra .. So I had 2 spares .. so I figured it was time to do some wiring since I had already run the grounds and power for the relays it was a 10 minute job ...........
awbrown is offline
Old 09-20-2012, 10:05 PM   #6142
jsdoyle
jsdoyle's Avatar
Changed the oil and cruised around. Also made me some iPhone wallpaper using a little app called Colorsplash.
jsdoyle is offline
Old 09-20-2012, 10:17 PM   #6143
r3skyline
Nice color! Too bad its not a LWB.
Old 09-20-2012, 10:22 PM   #6144
jsdoyle
jsdoyle's Avatar
I like it just fine! They are all good!
jsdoyle is offline
Old 09-20-2012, 10:40 PM   #6145
198plus
198plus's Avatar
Finished buffing my fenders today.
198plus is offline
Old 09-20-2012, 10:46 PM   #6146
towersddg9
towersddg9's Avatar
looking good
towersddg9 is offline
Old 09-20-2012, 10:53 PM   #6147
towersddg9
towersddg9's Avatar
Dropped my seat, door panels and visors off to get stitched up yesterday, its a glide engineering seat with the foam, mounts fit great, not gonna make the Goodguys show in October, but fer sure in March
Old 09-20-2012, 11:04 PM   #6148
jsdoyle
jsdoyle's Avatar
Wow! Looking very nice! What instrument panel is that? I like!
jsdoyle is offline
Old 09-20-2012, 11:10 PM   #6149
towersddg9
towersddg9's Avatar
Dakota Digital, its tip top, the panel itself is less than an inch thick runs off a cat 5 cable, no speedo cable has a sensor with a wire and it programs itself, mark off a mile and push the button, gives % to empty etc, Thanks for the input
Old 09-20-2012, 11:13 PM   #6150
jsdoyle
jsdoyle's Avatar
I gotta get me one of those! Very nice!
jsdoyle is offline
Closed Thread
