Old 09-23-2012, 09:56 AM   #1
biohazardbill
U-Haul trailer
Will our trucks fit on one? Any issues?
biohazardbill is offline   Reply With Quote
Old 09-23-2012, 10:14 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: U-Haul trailer
It will but if it has wide wheels or mags it might not. I have used one in the past and loaded it but it is tight.
LT1 Burb is offline   Reply With Quote
Old 09-23-2012, 10:19 AM   #3
Racer2172
Re: U-Haul trailer
They are tight on a stock truck, if renting they frown on it too, when I went to rent one to move my 65 years ago they refused to rent to me, when I told them what I wanted to haul on it.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 09-23-2012, 10:28 AM   #4
biohazardbill
Re: U-Haul trailer
I'm hauling a 1990 Honda civic lol.
The truck has no drive train so it shouldn't be too much weight. Was looking if overall dimensions would work. Shortbed.
Old 09-23-2012, 10:30 AM   #5
tincan1966
tincan1966's Avatar
Re: U-Haul trailer
Have recently hauled a '51 Chevy PU and a 1959 F100 on them. But both are significantly narrower than the 60-66's.
tincan1966 is offline   Reply With Quote
Old 09-23-2012, 11:29 AM   #6
dougf
dougf's Avatar
Re: U-Haul trailer
I just moved my '66 with wide mags from Virginia to Missouri on a Penske car hauler. What I did was measure the width of my tires and added two inches, then called and asked the width of the trailers. Both U-Haul and Penske had car haulers that were wide enough. I think I selected that I was hauling an El Camino or something. Good luck and drive safe!
dougf is offline   Reply With Quote
Old 09-23-2012, 11:33 AM   #7
biohazardbill
Re: U-Haul trailer
Mine is a short trip. Just don't have a car trailer at the moment. Thanks for the info.
Old 09-23-2012, 12:03 PM   #8
McCoyAZ
McCoyAZ's Avatar
Re: U-Haul trailer
I just hauled my 64 short step about 400 miles on a u-haul trailer, pulled it with a 2001 f-150
Then I went back and picked up and just used a tow dolly, pulled it back with the same f-150.
You will save a lot of money if you can use a dolly.
McCoyAZ is offline   Reply With Quote
Old 09-23-2012, 12:04 PM   #9
bighunting
Re: U-Haul trailer
I hauled a 63 1/2 ton w/ stock wheels on a uhaul trailer about six months ago with no problems. Uhaul wanted to know both what I was hauling and what I was pulling the trailer with and was fine with it.
bighunting is offline   Reply With Quote
Old 09-24-2012, 01:35 AM   #10
Captainfab
60-66 Nut
Re: U-Haul trailer
My son recently rented a Penske car trailer, and he was told as long as the vehicle is 4000# or less it is fine. A complete C10 long bed is over that, so keep that in mind.
Old 09-24-2012, 02:22 PM   #11
HeloCrewChief
HeloCrewChief's Avatar
Re: U-Haul trailer
Go with Penske. I used them to tow my 70 C10 from N.C. to California! Their equipment is much cleaner and safer than UHAUL.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 09-24-2012, 03:08 PM   #12
midniteblues
midniteblues's Avatar
Re: U-Haul trailer
just a thought if there is any hub caps remove them before loading. with the tight squeeze they could be damaged
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 09-24-2012, 05:12 PM   #13
XtremeBowtie
XtremeBowtie's Avatar
Re: U-Haul trailer
Hauled my 63 back with no problems:
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ!
My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342
XtremeBowtie is offline   Reply With Quote
Old 09-24-2012, 05:43 PM   #14
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: U-Haul trailer
That's how my panel made the 150+ mile trip home. I just told U-Haul I was towing a Miata.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-24-2012, 05:45 PM   #15
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
Re: U-Haul trailer
I was just wondering this same thing. Wanted to go to slamfest but no way I will be able to drive that far right now and no tag yet either.
I was wondering if I could air my truck up high enough to even get it on the trailer. Im not sure about a dolly, isnt it bad to tow an automatic in neutural????
MOTOIMPAIRED is offline   Reply With Quote
Old 09-24-2012, 06:02 PM   #16
62-One-Ton
62-One-Ton's Avatar
Re: U-Haul trailer
You could just remove the driveshaft. And for a dollie with no tags on the truck you will get a ticket.
62-One-Ton is offline   Reply With Quote
Old 10-10-2012, 09:05 AM   #17
78f1hundo
Re: U-Haul trailer
I know you guys have allot of info here, going to get my 66 c-10 long box. Will this fit the long way also?
Thanks allot....
78f1hundo is offline   Reply With Quote
