Old 09-23-2012, 08:07 PM   #1
rwolf9653
more ideas than money
rwolf9653's Avatar
Dual fuel tank help please
My grandfather has a 1987 V10 with the 305 and it cut out on him the other day. Now it will turn over, but not start. I spent a little time looking at it today and it is not getting fuel to the throttle body. I can hear a fuel pump run when it is on LEFT tank, but no pump noise when on RIGHT tank. I pulled the fuel filter and turned the key to the "ON" position and heard the pump run but no fuel came from the lines (left tank only, I tried right but no pump noise). I have not worked on the dual tank setup at all so can anyone explain this to me please?
Is there only one pump, or two?
There is only one fuel filter so I am assuming one tank pumps into the other? Left to right maybe?
It looks like the right tank is the main tank that feeds the throttle body, so if that pump quits there will be no fuel regardless of the LEFT pump working?
Any info is much appreciated. I hope to get the parts and make another trip down there to fix it, but he is two hours away so I would like to have what I need before I go.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 09-23-2012, 10:19 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Dual fuel tank help please
One fuel pump in each tank... 2 fuel pumps.
Not in stock dress. The selector valve switches the feed and return lines from Left or Right tanks to the engine compartment fuel feed and returns. The fuel filter is after the valve.
No.
It sounds like the selector has moved to the RIGHT tank then hung... And... the RIGHT tank has a fuel pump issue.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-23-2012, 10:26 PM   #3
superwade57
I'd unplug the selector switch and try jumping it. Odds are good in my experience that the selector switch went bad. I've had three go bad on me in the last two years. Three dif trucks. All of them sat for a couple years then woulndt start. That 12$ switch was the culprit on my 80,86 and 87. You can diagnose but operating the switch with key on truck off you should be able to hear the selector move its kind of a hollow clunking noise. For lack of a better term
superwade57 is offline   Reply With Quote
Old 09-24-2012, 08:58 PM   #4
rwolf9653
rwolf9653's Avatar
Thanks for all the help. I will go down there this weekend with a selector and a pump and I feel confident we can get it going. Thanks again.
Randy
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1987 Chevy V10
2003 Chevy Suburban
