Old 09-24-2012, 12:04 PM   #1
mvesr
Power steering
I just bought a 1968 SWB stepside 307 3 speed on the column and need to put power steering on so the wife can drive it. Where do I start?
mvesr is offline   Reply With Quote
Old 09-24-2012, 07:21 PM   #2
airdale94
airdale94's Avatar
Re: Power steering
Pump, brackets, gear box, pitman arm, hp hose, return line? Sometime after 75' they went to metric fittings on the pump and gear box.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 09-24-2012, 07:50 PM   #3
Chvy2NV
Re: Power steering
I'm also going thru this right now. Also have to see if you have long or short water pump.
Chvy2NV is offline   Reply With Quote
Old 09-24-2012, 08:28 PM   #4
geezer#99
geezer#99's Avatar
Re: Power steering
And the gearbox doesn't bolt on to some frames. You need spacers or a bfh to massage the frame.
Old 09-24-2012, 08:29 PM   #5
airdale94
airdale94's Avatar
Re: Power steering
I think the 307 trucks are long.
Old 09-24-2012, 09:10 PM   #6
Chvy2NV
Re: Power steering
I'd post some pics of what you have just to double check before you start buying stuff.
Old 09-24-2012, 09:17 PM   #7
71swb4x4
71swb4x4's Avatar
Re: Power steering
If it was me, I would buy a 71 - 87 parts truck and take the power steering, power brakes, and disc brakes and put them all on this truck. If the parts truck has HEI, a front sway bar and an internally regulated alternator I would swap those parts over too. Actually with the power steering, power disc brakes, sway bar, HEI and internally regulated alternator you will greatly increase the driveability of the truck.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is online now   Reply With Quote
Old 09-24-2012, 09:20 PM   #8
Chvy2NV
Re: Power steering
This sounds like a great idea. Might be a lot cheaper too. What are these trucks going for
Old 09-25-2012, 09:19 PM   #9
mvesr
Re: Power steering
Thanks for all the ideas. My truck has a short water pump
Mika
