Old 09-25-2012, 09:37 AM   #1
98layinframe
98layinframe's Avatar
anyone running the C4 suspension front and rear?
First off sorry if this has been asked many times.. but for some reason the search features wont open/ work on my phone.
Anyways.. Im planning to run C4 suspension under my 51 but I've got a ton of question's!
Anyone here bought the expensive box tubing crossmember setup to run up front?
What flexibility does it allow for wheel width and backspacing? I have 18x8" 4.5" backspace wheels I'm looking to run.
for the rear setup.. there again I guess the wheel choice has a major role, but do most guys leave it full width or narrow the drive tubes?
Anyond have pics!?
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 09-25-2012, 09:46 AM   #2
robin58
Re: anyone running the C4 suspension front and rear?
Which one are you looking at? Progressive's or Flat Out's? I have Flat Out's front C4 installed on a 51 Suburban but haven't gotten to choosing rims yet. But in mock ups it really doesn't look like there's much room to play around.
robin58 is offline   Reply With Quote
Old 09-25-2012, 10:12 AM   #3
98layinframe
I was looking at flat out's narrowed rack set... if I read it right it sets the track width at about 57"?
Old 09-25-2012, 10:20 AM   #4
robin58
My front measures 59 1/2" I think brake face to brake face (according to my notes in my little book), but that's because I used 86 C4 parts. I think 87 and newer are wider. I'll go outside in a bit and measure it for sure.
Old 09-26-2012, 10:27 AM   #5
98layinframe
Whats the specs on the wheels your running? Im wondering if a 59" suspension setup is going to be to wide for the 18x8" 4.5" backspacing wheels I have to tuck up inside the fenders and be able to turn at all.
Old 09-26-2012, 10:54 AM   #6
texlurch
Not sure on specs but a lot of the guys running the Mustang II are running 17x7 or 18x7.
I'm planning on the C4 setup, here are my notes:
Stock AD rear width, flange to flange 60-62” (not sure on stock front)
88-96 vette Front 60-1/2”, rear 62-1/2” (rotor face to face)
The earlier C4 is a bit narrower like 1/2 inch. Flatout has the specs on their page.
The lower you go the wider it gets obviously.
texlurch is offline   Reply With Quote
Old 10-02-2012, 04:16 PM   #7
98layinframe
Yeah guess the earlier pre 87 front is an inch or approx narrower. Wonder if the arms are different or the spindles?
Does anyone have some pics?!? Anyone...
Old 10-02-2012, 05:59 PM   #8
crossfire84
crossfire84's Avatar
this is my 85 c4 in my 50 3600, made the set up my self.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 10-02-2012, 06:23 PM   #9
98layinframe
Very cool! Nice work man! Whats the specs? Stock width irs? Whats the wheel spec.. size and backspacing? Just trying to judge ic i should use my narrowed irs or the stock width one.
Any chance your running c4 front?
Old 10-06-2012, 05:51 PM   #10
Coronas56
Coronas56's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=260417
Semper Fi!
Coronas56 is offline   Reply With Quote
Old 10-20-2012, 01:27 PM   #11
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
I think.....the kit itself is pretty good if you install it the way they want you too....if you want to do a bigger notch in the back to lower it more, you end up cutting everything up but atleast it's all there to start from. I have only seen one truck finished and the guy said he loved the way it drove......I hope to know myself in a couple more weeks....
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 10-20-2012, 01:38 PM   #12
98layinframe
Yeah I'll probably end up buying a front crossmember but out back is just to easy to setup and build plus my rear will be narrowed and the butterfly mount wont be full width so it fitz inside the narrow frame.
