Old 09-27-2012, 10:33 AM   #26
custom1970
Member
custom1970's Avatar
Re: 6x9's in the door - Yes Or No??
If your doors aren't cut I would advise not to cut them. I made some boxes for 6 x 9 to fit under my seat and was able to get some thinner grills so my kick panel speakers would clear the E-brake. I know it's not going to win any sound contest but it really does sound pretty good.
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 09-27-2012, 10:54 AM   #27
GoaterAz
GoaterAz's Avatar
Originally Posted by ls1nova71 View Post
I cut mine. Stereo sounds better with them in the doors in my opinion. Now that I said that, I can tell you how to make them look good, almost factory, and almost unnoticeable. Find some speaker grilles from the package tray of many GM cars from the 70's. they look OEM because they are, just not in this application. Paint them to match the door, mount the speaker with the nuts from behind (no screws show) and you're done.
Not the best pic, but what I could find, since it's too dark right now to go out and take a pic. You get the idea.
That looks great!
Do you by chance have any more installation pictures of this setup?
GoaterAz is offline   Reply With Quote
Old 09-27-2012, 11:30 AM   #28
67chevemall
67chevemall's Avatar
Originally Posted by CC69Rat View Post
Roll the window down, prop your arm out and just listen to the truck. I wouldn't mind if my truck didn't have a radio really. My GMC has one but it doesn't work. It's on the bottom of my list to get it working. No way I'd cut my doors. Just my opinion. I'd say No.
Is the tank in the cab? There is a guy on the forums that sells custom speaker enclosures for the back corners of the cab (if that's an option)
Ya the motor sounds to great to ruin with radio waves.....no stereo for me.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 09-27-2012, 12:37 PM   #29
Lippyp
English Chevy Owner
Lippyp's Avatar
Originally Posted by Dano69c10 View Post
My doors are already cut for 6" x 9"s, I was just wondering if they make a cover for the back of the speaker?
Thanx in advance,
Dano
They do make waterproof buckets to fit behind them, crutchfields sell them although unfortunately I can't seem to find them here in the UK as the previous owner cut mine for 6x9's and despite fitting new window seals they still leak.
http://www.crutchfield.com/p_237XT69...th.html?tp=660
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 09-27-2012, 12:39 PM   #30
heathbirkendahl
Originally Posted by Lippyp View Post
They,crutchfields sell them although unfortunately I can't seem to find them here in the UK as the previous owner cut mine for 6x9's and despite fitting new window seals they still elak.
I used these in my last truck and they work killer. In fact they create a box which gives the speaker more bass.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 09-28-2012, 11:32 AM   #31
N2TRUX
Happy to be here
N2TRUX's Avatar
I don't know what the big deal is about putting speakers in the doors. I'm one of those guys who cut the doors you guys are griping about. Been doing it for decades. It's the best place for them.
Tim I usually agree with most of your posts but not this one. I am not opposed to cutting the doors, but the lower panel is not a good spot to put speakers.
The speakers found in many of the current cars/trucks are not mounted that low, and are usually part of an integrated speaker system. Throwing a set of 6x9's in a hole near your feet is a horrible location.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-28-2012, 01:04 PM   #32
biggestjohn
An option:
Bucket is molded fiberglass sandwiched between two foam bowls.
Fenders must be off, will cut thru small section of cowl vent, that must be resealed. sealed with seam sealer. There will be carpet kick panel added later.
The only way that I could find to clear parking break.
......its not what your askin', its what your gettin'....
.......every time I screw up, I learn something. Needless to say, I'm learning all the time............
biggestjohn is offline   Reply With Quote
Old 09-28-2012, 01:04 PM   #33
biggestjohn
Old 09-28-2012, 06:22 PM   #34
Steve Cole
LS1Nova71: those doors look so good it makes me want to cut mine! And I don't even have a radio!. Seriously, they look good.
Steve Cole is offline   Reply With Quote
Old 09-28-2012, 06:28 PM   #35
heathbirkendahl
I could see those being resold!! You make a combo kick panel with that built in. I'd by some.
Old 09-29-2012, 12:57 AM   #36
biggestjohn
No need to make them. Its a cheap DIY solution. If I had known about the buckets that Crutchfields has, would have been even easier,
BTW: I should have said the buckets are sealed to the kick panel with seam sealer.
Old 09-29-2012, 06:01 AM   #37
jjzepplin
jjzepplin's Avatar
Left my truck out in the rain one day..(Florida flash flood) and thought "I better go get her or she's gonna get mad at me. So I went out in the lightning to save my project...opened the door and heard something funny. Shook the door back and forth and it seemed heavy and made a sloshing sound. YEP half full of water. Drain holes were plugged with junk,debris,and cigarette butts (I don't smoke). Cleaned out the doors and the drains let it all dry and the speakers still work.
My truck is no show winner but it will pull a stump out and tow a train. She is also kinda loud so the more tunes the better. 4 12"'s in the back and 6x9's in the doors ,4x6's in the cowl vents and 3" behind up high in the corners...All holes are already there so it's cheaper than welding since I also have all the speakers already.
SO..no holes no speakers.
Got holes-fill them with tunes.
Just make sure your gauges work?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-29-2012, 10:41 AM   #38
big mike71
big mike71's Avatar
I put 6x9s behind seat and built this little box, So I wouldn't have to cut my doors or my dash.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 09-29-2012, 11:45 AM   #39
biggestjohn
If you relocate the gas tank, it opens up a world of space for really important stuff, like speakers and amps!!
6x9s would fit nicely in the rear corners.
