09-27-2012, 02:02 PM | #1 |
what should i do to my '86 K10? appearance wise?
alright I'm not sure what i should do as far as appearance on this truck. i've got the tint on all the windows done,
I was thinking a bumper like this with some lights. Where can I find this style front bumper guard? this is my truck should i also get a sun visor too? i mean I'm having a hard time deciding on what to do appearance wise to this truck i don't want it to be tacky and take it straight to the 80's but i want it to look damn good. The steps no longer exist, i sold them. Last edited by yellow400ex05; 09-27-2012 at 02:10 PM. |
09-27-2012, 03:44 PM | #2 |
What Hump?
Re: what should i do to my '86 K10? appearance wise?
In my opinion DO NOTHING!!!!!!! it looks perfect just the way it is, but if your looking for a brush gaurd like on the silver truck just check your local craigslist I'm sure you can find one, if not there check any 4x4 magazine.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
09-27-2012, 08:46 PM | #3 |
I would put a double/double rollbar and some KC's just like it would have had back in the day
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB Last edited by 88Jimmy4x4; 09-27-2012 at 09:15 PM. |
09-27-2012, 08:49 PM | #4 |
I put the rest of the bumper bolts on and drive the heck out of it. No visor, no lights. It looks awesome the way it is.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-27-2012, 08:56 PM | #5 |
+1, sometimes "clean" is the best accessory
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
09-27-2012, 08:57 PM | #6 |
I think it works the way it is.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
09-27-2012, 09:23 PM | #7 |
I wouldn't do anything to it, it looks perfect the way it is.
85 GMC SWB: Fuel Injected 454, TH400, soon to be laying frame on 22s 96 Trans-Am: Full bolt-ons, Weld Rodlite skinnies and fatties 95 GMC Yukon 4x4: 2door all stock with the exception of glasspacks and duals |
09-27-2012, 09:55 PM | #8 |
I wouldn't do anything other than install the missing bolts in the front bumper.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
09-27-2012, 10:05 PM | #9 |
aluminum dif' covers and take it down a few inches. looks to high for on road use, and off road use for that matter. loose the steps adn get some rallies
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
09-27-2012, 10:15 PM | #10 |
78K & 79C Jimmys
looks nice but if you drive outa town in the country a lot like me,
lights to see the deer are a good thing
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-27-2012, 10:52 PM | #11 |
I would swap off the chrome covers and put either original covers on it or aftermarket 'beefy' and get different steps otherwise its good. Although i haven't seen a dual headlight step side yet that also might be interesting but that front end looks awesome on it
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
09-27-2012, 11:46 PM | #12 |
i wouldnt bolt any garbage on it.....looks nice.....i like 6-8 inch lifts with 35 or 37's......but on step sides i think 2-4 with rallies and 33's look best....
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
09-28-2012, 04:56 AM | #13 |
Not a fan of steps but you can pull them off. It looks good the way it is.
1976 k10 2003 reg cab 1500 Gig'em Aggies |
09-28-2012, 06:52 AM | #14 |
Leave it the way it is man, it looks awesome. I wouldn't change a thing!
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
09-28-2012, 08:37 AM | #15 |
I would leave it alone. Maybe factory side emblems. thats it
09-28-2012, 09:01 AM | #16 |
I'd remove the steps unless you got kids that need to climb in and out.
Edit: Are you running steering stabalizer? |
09-28-2012, 02:55 PM | #17 |
I'm with the majority here, don't change a thing.
But put those bumper bolts in. And get the rust on the doors fixed. And if the rust had gotten a hold in there, its other places as well. Now is the time to fix and protect it. My 83 looked like that when I parked it. A few years later the cab fell to the frame. Floors, rockers, supports all toast. Now is the time to go under it, scrape, sand, brush and slop some POR 15 all over the underside. A good flat black over the POR 15 and you'll be good to go. ...maybe not exaclty "slop" it on. The rest of your paint is too good to risk by "slopping". BTW - the truck looks great. I'm more than a little jealous. |
09-28-2012, 08:16 PM | #18 |
first thing I would do is get rid of the stacked rear blocks
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
09-28-2012, 09:53 PM | #19 |
I would fix the only bit or rust it looks like your truck has on the door. Other than that it's perfect, looks great.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
09-29-2012, 01:11 AM | #20 |
personally i didn't mind the 80's, as long as your truck is real underneath. have a visor on mine, get used to neck craning at lights, also got the same steps as you, didn't want them, wife did- will grow on you after awhile. other then a few minor mechanicals, the only thing i would do is add a billet grill, that'll give it a nice smooth look, them 80's grilles just look to plasticky
09-29-2012, 01:23 AM | #21 | |
the whole underside of the truck is beautifully undercoated with not one tiny spec of rust under the whole truck. the bolts for the front bumper i guess I'll have to pull them off another 80's truck at the pull apart yard. the steps were gone a day after i got the truck. I do plan on getting rid of the stacked blocks soon. give me a little bit haha for now i just wanna drive it. I'm doing cherry bombs on the truck tomorrow as well |
09-30-2012, 12:39 AM | #22 |
Clean truck, maybe chrome steps and wheel well mouldings for the rear. Someone posted my 76 Chevy Sport above, I just removed the pushbar for a cleaner look the other night. Like the look of the chrome pushbar on the 81' to 87'. Here my 83'.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
