Old 09-28-2012, 05:44 PM   #1
RedSierra
leak. Bad News?
Ok so I found out today that there is a good possibility that the Rear Main Seal is leaking. You all have been so helpful... Wanted to see what you thought.
Is this a big, expensive problem?
Remember this is all new to me.
Red Sierra
RedSierra is offline   Reply With Quote
Old 09-28-2012, 07:29 PM   #2
str8axle55
Re: leak. Bad News?
What year truck/motor, 86 and up have a 1 pc rear main. If it`s a 1 pc, the trans will need to come out.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 09-28-2012, 08:20 PM   #3
RedSierra
Re: leak. Bad News?
It's an 86.
Red Sierra
Old 09-28-2012, 10:34 PM   #4
79 silverado
Re: leak. Bad News?
How bad is the leak?
I've driven a vehicle with a very slow rear main leak before that I left in and just kept topped off with oil since it dripped rather slowly and I kept an eye on it to make sure it didn't start losing too much oil. It stayed that way for 6 years and never needed changing, lasted until the vehicle was stolen and recovered, then parted out. That one it acted more like the weep from a valve cover and didn't hurt anything
On the other hand, I've seen engines where you run them at idle in the parking lot and you can see the oil drip drip drip out like a leaky faucet, which required changing...
79 silverado is offline   Reply With Quote
Old 09-29-2012, 12:10 AM   #5
RedSierra
Re: leak. Bad News?
It is a pretty good size leak. Sounds like I should get it changed.
Red Sierra
Old 09-29-2012, 07:08 AM   #6
str8axle55
Re: leak. Bad News?
Do you have a factory oil cooler, those have been known to leak where the o-ring seals to the block.
84 Chevy K30 CC SRW
Old 09-29-2012, 01:33 PM   #7
RedSierra
Re: leak. Bad News?
Yes. Everything is factory. Is the oil cooler hard to get to and check?
Thanks for all the help!
RedSierra
Old 09-29-2012, 02:13 PM   #8
chebyshortbox65
chebyshortbox65's Avatar
Re: leak. Bad News?
Put it up on jackstands clean really good and remove the trans inspection cover and run it to verify where the leak is
chebyshortbox65 is offline   Reply With Quote
Old 09-29-2012, 03:56 PM   #9
RedSierra
Re: leak. Bad News?
Great! Thanks
RedSierra
