Old 09-28-2012, 07:59 PM   #1
shipma2
what transmisson fluid to use in a th350
what transmisson fluid to use in a th350 transmisson ? will dexron work in it or should i use something else? also my transmisson leaks like a syfe i think it maybe the pan seal, but the kicker is the th350 is behind a 454 which worries me, i have heard horror stories about them being prone to failure behind a 454. any tips or suggestions for my 78 k10 would be greatly appreciated thank you
shipma2 is offline   Reply With Quote
Old 09-28-2012, 08:44 PM   #2
mopar346
Re: what transmisson fluid to use in a th350
Dextron or any of the derivative should be fine. My fix suggestion is fix what is leaking immediately, then I would probably find a 400 to put in it. A 350 coudl be built to live fine behind a 454 but it will cost a little. The other fact is jsut saying it a 454 doesn't really clarify things. A fire breathing 500 horse 454 is gonna make small work of it, a lame (no offense) smog 454 wont give it any trouble. AND it depends on what's inside of your current 350, I think there are different drums that hold a different number of clutches for more strength. I know this is the case with many tranny and I believe 350s as well, but I could be wrong, remember I'm a Mopar guy.
mopar346 is offline   Reply With Quote
Old 09-28-2012, 09:25 PM   #3
cory d
cory d's Avatar
stock 454?
cory d is offline   Reply With Quote
Old 09-28-2012, 09:36 PM   #4
meter swinger
meter swinger's Avatar
I have done my own tranny gaskets in the past but honestly, its a pain in the a$$ working undernearth a tranny unless you have a lift.
I have a tranns guy that will do a filter, pan gasket, and fluid on a 350 for 65 bucks. Worth every penny.
Check the side of the unit to see if your leaking out of the shifter area or where the cable goes in.
Find a reputable trans shop. If you need a rebuild on your 350 it probabky wont be much more to swap in a 400.
meter swinger is offline   Reply With Quote
Old 09-28-2012, 09:51 PM   #5
clinebarger
The number 1 & 2 causes of transmission failure are low fluid level, As mopar346 said....Fix the leak.
A TH350 can be built to handle your 454 mild to wild.
If you didnt have the existing TH350 rebuilt....It probably needs it anyway.
clinebarger is offline   Reply With Quote
Old 09-29-2012, 06:22 PM   #6
shipma2
it is stock, from a 1973 i belive, the motor is not original to the truck as the vin states a 350 4 barrel, though i have reason to belive four or five motors and transmissons have been in it lol
