09-29-2012, 04:34 AM | #1 |
Corvette Wheels?
Are there any Corvette wheels that will fit my '83 stepside?
Im guessing they would have to be the 5x5 bolt pattern to work? |
09-29-2012, 12:09 PM | #2 |
Re: Corvette Wheels?
You can change your bolt pattern to 5x4.75 easily enough, but as far as offset and whatnot, I'm not sure. But a set of Z06 style wheels would look tasty on your stepper.
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
09-29-2012, 12:16 PM | #3 |
No...
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
09-29-2012, 01:46 PM | #4 |
whats involved with changing the bolt pattern? The hubs or?
09-29-2012, 03:08 PM | #5 |
bolt pattern can be changed by redrilling tha rotors & axles/drums..but tha backspace is the bigger issues..quality spacer/adapters will have to be used.
09-29-2012, 03:14 PM | #6 |
ABS brakes in Orange,CA makes a rotor in 5on4 3/4 bolt pattern. Have the rear re-drilled. Otherwise adapters. Most adapters are an inch thick. If your talkn about modern vette wheels, they have a FWD offset. Really hard to pull that off on these trucks. Best bet is to choose different wheels.
09-29-2012, 06:05 PM | #7 |
I read some where on here also that you can get a certain year camaro front rotor that has the exact same dimensions as a square body front rotor.
1979 SWB 350/350 |
09-29-2012, 07:40 PM | #8 |
Are you talking about the corvette rallies?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
09-30-2012, 08:55 AM | #9 |
Not rallies-I was thinking about newer era wheels from the C4s and C5s.
09-30-2012, 04:04 PM | #10 |
Ah those will have to be run with large spacers/adapters like four inch thick ones
09-30-2012, 04:28 PM | #11 |
I like the old Vette rallies, I thought they were a direct fit, DAMN
2004 Silverado Crewcab (Dark Spiral Gray) |
09-30-2012, 05:27 PM | #12 | |
