Old 10-02-2012, 09:53 PM   #1
Justin36
Justin36's Avatar
1967 One Barrel Rochester running really rich??
Hey wondering what to do? Carb running way rich, can smell gas pretty bad at pipes, new points, plugs wires, etc and still doing it.... Any advice? Thanks Justin
Justin
Justin36 is offline   Reply With Quote
Old 10-02-2012, 10:54 PM   #2
Wrenchbender Ret
Re: 1967 One Barrel Rochester running really rich??
There is a hole in the bottom of the carb that must have a passage way into the intake manifold. Cut a chunk out of the base gasket if nessesary. If thats not it you need to tear down the carb & put a kit in it. Make sure the float does not have gas in it. Make sure the power valve piston is not stuck.
Wrenchbender Ret is offline   Reply With Quote
