Old 10-05-2012, 11:30 PM   #1
bmph8er
backspacing help asap please
i have a 72 c10. i lowered it with belltech spindles so now i need wheels my front 15 inch wheels no longer fit. im ordering 17s b/c i can get free tires at work. the wheels im looking at are 17x8 with 5.25 backspace or 4.5 backspace, and for the rear 17x9 with 5 backspace or 6 backspace. since i have the 72 with the wider rear end i think i need more backspacing is that right? thanks
bmph8er is offline   Reply With Quote
Old 10-06-2012, 08:26 AM   #2
bmph8er
Re: backspacing help asap please
if anyone can help id be greatful. i need to get wheels ordered so my truck isnt sitting on jackstands in the middle of my garage. thanks
Old 10-06-2012, 09:01 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I would run the 5" BS on the rear 17x9 wheels,... if that's your best option.
6" BS will be too much.
Up front a 5" BS would be better for your 17x8 wheels,... so I guess choose the 4.5" BS if you have to have these wheels.
I personally, would grind your lower a-arms so your 15" wheels would work.
You never know when you will have to install the spare or other 15" wheels.
Keith
Convert to disc brakes.
Old 10-06-2012, 09:39 AM   #4
bmph8er
The lower control arms isn't the problem. I ground them they clear fine. The wheel is rubbing on my caliper mount on the spindle. I never seen it happen before but it is. It's ok tho I wanted different wheels just wasn't ready yet. Oh well that's life thanks for the reply
Old 10-06-2012, 10:04 AM   #5
bmph8er
Forgot to put I have a 5/6 drop and will have 245/45r17 front 275/40r17 rear. Freebies from work
Old 10-06-2012, 12:14 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I used a 4-inch BS up front and a 5-inch BS out back, on my '69. Front wheels are 8-inches wide, while rears are 10-inches wide.
Member Nr. 2770
