Old 10-06-2012, 08:29 PM   #1
MDc10
MDc10's Avatar
Throttle cable/ Kickdown cable bracket mounting
Could and help me with this l, maybe some pictures. I purchased a bracket from jegs with a 700r4 adapter, basically the adapter is a flat price of metal with 6 holes and a offset. I'm having trouble figuring out how this bracket and adapter goes. Any way I mount it something is wrong, if anyone has a SBC with a edelbrock carb and this same setup I would greatly appreciate a picture, any info you guys could share would be great, Thanks.
MDc10 is offline   Reply With Quote
Old 10-06-2012, 10:26 PM   #2
nascarmikeb
Re: Throttle cable/ Kickdown cable bracket mounting
i just went through this w/ summit. canyou list the part # it took me a while to figure it out as well. but i finally got them in the right position. i have 350 sb, 700r4 and edelbrock carb
nascarmikeb is offline   Reply With Quote
Old 10-06-2012, 10:30 PM   #3
nascarmikeb
this is what i ordered and it finally worked!
SUM-G1414 - Summit Racing® Adjustable Throttle Cable Brackets
www.summitracing.com/parts/SUM-G1414/
Old 10-06-2012, 11:13 PM   #4
MDc10
MDc10's Avatar
What I ordered through jegs is, bracket # 555-157060, 700r4 adapter # is 865-2429. I'm not sure if it is the right set up or not. Do you have a picture of your setup?
Old 10-06-2012, 11:23 PM   #5
MDc10
MDc10's Avatar
from what i can tell from the summit magazine, this looks like what I got, I just can't figure out how to put it in.
Old 10-06-2012, 11:30 PM   #6
nascarmikeb
yes, tomorrow during daylight i will post pics
it took me SEVERAL attempts before i figured it out, but it works. i will post pics of my setup
i swappped from tbi 305 to 350 carbed, so i had to reconfigure, works fine now
mike
Old 10-07-2012, 02:20 PM   #7
MDc10
MDc10's Avatar
I would really appreciate some pics, thank would help me tremendously. Also did you hook up the spring of leave it off? I've seen conflicting info about the brackets, so I don't know what to believe, but if it works on your setup it should work on mine, it sounds like we.have the same setups. Thanks for your help.
Mike
Old 10-07-2012, 04:03 PM   #8
nascarmikeb
ok, try these. not sure if you can see what u need, if not let me know i will try from other angle
mike
Old 10-07-2012, 04:04 PM   #9
nascarmikeb
one more pic
Old 10-07-2012, 05:52 PM   #10
MDc10
MDc10's Avatar
Is your spring hooked up?
Old 10-07-2012, 09:42 PM   #11
nascarmikeb
yes the other end of the spring is hooked to the front of the manifold. that is the throttle return spring.
mike
Old 10-08-2012, 09:45 AM   #12
MDc10
MDc10's Avatar
Really appreciate your help and the pics, im gona have to modify my bracket, because of the kickdown cable and the way the end adjustment is but it's gona work. Thanks for your help.
Mike
Old 10-08-2012, 10:07 AM   #13
byeoficr
I had the same issue so I used this to make sure the TV cable worked properly. It was about $20 on eBay.
byeoficr is offline   Reply With Quote
Old 10-08-2012, 01:36 PM   #14
nascarmikeb
Hey MDc10
On the end of my TV cable, the little alignment detent, was not allowing me to orient the cable into the bracket. I took my utility knife, and basically trimmed the alignment detent off. This way the end of the cable went into the bracket and was held in place by the side "wings" that have to be depressed to inorder for it to be removed. Works perfect.
Mike
Old 10-09-2012, 07:47 AM   #15
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Here is the best bracket I found that will not bend. It's from Edelbrock. You do have to remove or relocated the stock cruise. I have an aftermarket cruise in my truck.
http://rides.webshots.com/photo/2083...54440533NjEHgc
I tried several until I used the one above. It works great. I even had it modified for my taller intake.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-10-2012, 08:55 AM   #16
Hertzdaddy
I may have one of these laying around if anyone needs one. Opened but never used. PM me if interested.
Hertzdaddy is offline   Reply With Quote
Old 10-11-2012, 10:47 AM   #17
kody
gchemist,do you have part # for the edelbrock bracket? can't find on jegs website.i like the looks of that one.
kody is offline   Reply With Quote
Old 10-11-2012, 11:34 AM   #18
gchemist
gchemist's Avatar
Edelbrock 8036 cadium plated
Edelbrock 8030 chrome
Edelbrock 8029 LS bracket
Old 10-11-2012, 12:34 PM   #19
kody
thanks,jegs has them.
