Old 10-07-2012, 03:45 PM   #1
calvin78612
calvin78612's Avatar
Leak
Found a leak on my brake prop valve,it's leaking from the plastic piece on the side of valve it's a CCP valve # PVK-2A,hope i put the link in here right.Any help would be great,couldn't find anything on the CCP site,Calvin
http://www.classicperform.com/Store/.../pv-2-pv-4.jpg
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 10-07-2012, 09:34 PM   #2
calvin78612
Re: Leak
Anybody ?
84 step side
87 swb
Old 10-09-2012, 08:14 AM   #3
calvin78612
Re: Leak
Could an admin. move this to the engine section.thanks.
84 step side
87 swb
Old 10-09-2012, 09:11 AM   #4
Lee H
Lee H's Avatar
Re: Leak
Have you called CCP?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-09-2012, 09:11 AM   #5
Fldawg
Fldawg's Avatar
Re: Leak
do you use the brake light sensor, if not just take it out and plug it with the right brass fitting.somebody please correct me if i'm wrong
Fldawg is offline   Reply With Quote
Old 10-09-2012, 09:15 AM   #6
1970 C10 MJW
1970 C10 MJW's Avatar
Re: Leak
if i knew what was causing it i would happily help out but i am not sure..... but at least my reply will keep this towards the top
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 10-09-2012, 09:23 AM   #7
calvin78612
Re: Leak
I was not sure if it was the brake light sensor,have no paper work on it but i will pick up a plug today,Thanks for the reply.
84 step side
87 swb
Old 10-09-2012, 09:26 AM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Leak
Calling CPP is your best option.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 10-09-2012, 10:07 AM   #9
GMCJOE
GMCJOE's Avatar
Re: Leak
Is the plastic cracked, or is it just leaking out from the bottom of it. I think it screws out, so you could possibly take it out and put some thread tape on it and get it to seal.
But I would say give Jeff a call at CCP and see if he will send you a new one out or at least help you resolve your issue.
Here's Jeff's contact info from another thread. 888-522-8303 ext 118 jeff@classicperform.com
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 10-09-2012, 10:12 AM   #10
calvin78612
Thumbs up Re: Leak
Doesn't seem to be cracked,it's not a daily driver so for now i'll plug it and give Jeff a call later on today.Thank guys.
84 step side
87 swb
