Old 10-09-2012, 12:40 AM   #1
1972SUPERSB
1972SUPERSB's Avatar
Need pic of tach wire through firewall
Does anybody have a picture of the correct location of where the tachometer wire should come through the firewall? Mine comes out with the speedo cable I'm sure this is not right. Thanks
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 10-09-2012, 01:32 AM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Need pic of tach wire through firewall
Subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-09-2012, 07:48 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I think 72BlckButy had a thread on this.
I'll look.
Keith
Convert to disc brakes.
Old 10-09-2012, 07:51 AM   #4
lolife99
lolife99's Avatar
This is where Nate drilled the hole on his '69.
Were there different locations for different year trucks?
Keith
Old 10-09-2012, 01:19 PM   #5
FirstOwner69
FirstOwner69's Avatar
The Assembly Manual shows different routings (I think two) for the wire depending on the year. The location above appears correct for 72. As I recall (don't have the manual here) it shows the wire passing through one of the grommets near the distributor for at least the 69s and earlier. I think it's the grommet the oil gauge line passes through.
If someone has other definitive info regarding the original factory routing for the 69s I'd be very interested.
FirstOwner69 is offline   Reply With Quote
Old 10-09-2012, 05:45 PM   #6
rustypu
I just drilled one today, the above pic is correct. I checked a 72 GMC W/tach before I drilled
rustypu is offline   Reply With Quote
Old 10-09-2012, 05:59 PM   #7
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
This might show the early cab style, not 100% sure
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 10-09-2012, 07:37 PM   #8
weaintscared
weaintscared's Avatar
Subscribed.
weaintscared is offline   Reply With Quote
Old 10-09-2012, 11:22 PM   #9
67chevy1series
67chevy1series's Avatar
does anyone know where the whole is on a 67 68 cab?
67chevy1series is offline   Reply With Quote
Old 10-10-2012, 12:00 AM   #10
1972SUPERSB
These pics will help a bunch. I'm gonna drill mine tomorrow
Jeff
Old 10-10-2012, 12:50 AM   #11
FirstOwner69
As I noted above in post 5, the Assembly Manual shows it going through an existing grommet (I think the one the oil line goes through) for the 69s and, I believe, the 67s and 68s as well. I don't have the assembly manual with me, but I can double check in a couple days and post that info.
It would be great if owners of 69 and earlier trucks equipped with tachs from the factory could confirm if this is what was actually done. I plan to put a tach dash in my 69 and would like to know also.
Old 10-22-2016, 05:15 AM   #12
gmc 2500 4x4
good info. how about a vacuum line?
gmc 2500 4x4 is offline   Reply With Quote
