Old 10-09-2012, 09:09 PM   #1
whoryou1979
whoryou1979's Avatar
Turn Signal Question
When I pull out my headlight switch, both of my turn signal indicators illuminate. Both of the turn signals work, blink, when commanded, but stay on otherwise. Anybody ever run into this?
All Day Every Day
'72 C20 Cheyenne Custom Camper
http://67-72chevytrucks.com/vboard/s...d.php?t=549132
whoryou1979 is offline   Reply With Quote
Old 10-09-2012, 09:26 PM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: Turn Signal Question
More than likely a ground issue. Try seeing if the dash ground is bad are try a jumper wire to ground it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-09-2012, 09:57 PM   #3
oklalawnboy
oklalawnboy's Avatar
I vote bad ground OR maybe those little cardboard tubes are missing that keeps the gauge lights from shining through the blinker holes.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 10-09-2012, 11:18 PM   #4
tim21391
tim21391's Avatar
i second the cardboard tubes... also id check the rear taillights.. they need to have two screws/bolts in the housing before the lense goes on.. i had a major headache when i only had one in... left blinker made brake lights come on.. headlights pulled out it made blinker work.. all sorts of nonsense...
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
