Old 10-12-2012, 12:40 PM   #1
osaltyone
osaltyone's Avatar
Fuel problem again
So a couple months ago I was getting the light and it was lean on both banks. I changed the fuel filter to a decent one from Jegs because I thought it was clogged. Fixed the problem for a short drive around the block then fuel cut out and I pushed it home. Changed the fuel pump thinking that was the problem even though it was a new Walboro. Seemed to do the trick, let it run for 30min and a few runs around the block and I thought I was good.
Had to use the truck this morning, so took it out this morning for a real run and it died on me when I stopped at a light and I couldn't get it started.
Had it towed back home. I was thinking maybe it got vapor locked or something, so I hit the schrader on the fuel rail and fuel dripped out, no pressure...I turned the key on and off a few times checking at the schrader and didn't seem to have a lot of pressure. Hit the key a few more times without starting and Wham it started and runs fine now.
Any ideas on why I would see this odd issue? I haven't really driven it too much before this because I did not want to break down.
osaltyone is offline   Reply With Quote
Old 10-12-2012, 01:21 PM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Fuel problem again
Could be the fuel pressure regulator, allowing rail pressure to bleed off to the tank. That is of course, assuming you're running a truck style return system.
Also, is the tank vented? If not, pull the cap off and take it for a ride to see if that solves the problem.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-12-2012, 02:19 PM   #3
osaltyone
osaltyone's Avatar
I can replace the regulator on the rail to see if that helps. The tank does has a vent hose on it. I have tried to start the truck when the issue is going on with the cap off and no luck.
Old 10-12-2012, 04:31 PM   #4
Wasted Income
Boosted Member
If the rail won't hold pressure, I'd say it's a regulator. Put a pressure gauge on the schrader valve (pull the core out first) and make sure it's even getting up to full pressure, to ensure it's not a restriction on the supply side.
Turbo diesel
Old 10-13-2012, 12:22 PM   #5
74project
Ive had the same problem...i switch during the swap to a returnless style but did not change the fuel rail and kept the regulator still hooked up to the manifold. My truck would drive fine then completely out of the blue die out...the only way it would restart was if i capped the manifold and fuel regulator on the fuel rail then for some reason it would start back up and has been running great ever since. I did have to adjust my ecm to lower fuel pressure which was causing it to run rich. Hope it helps..
74project is offline   Reply With Quote
Old 10-14-2012, 05:53 PM   #6
osaltyone
osaltyone's Avatar
New regulator did not help. Today it seemed to happen Just before I got up to temp. I got it back in the garage by putting it in park just as it was about to die, then rev'd it a bit which got it going again and pulled it in the garage. Going to go rent a pressure gauge from autozone now...
Old 10-14-2012, 06:50 PM   #7
osaltyone
osaltyone's Avatar
Fuel test gauge shows 48 on first start then once warmed up 50. When I put it in drive, hold the brake and give it has I get up to 60. No codes now, but looks like it threw p0171 & p0174 earlier. Probably when it was dieing.
Old 10-14-2012, 09:01 PM   #8
osaltyone
osaltyone's Avatar
would it matter that my VSS is not hooked up yet? I have the dakota digital guages, just haven't wired them yet. I thought it was just to tell the pcm when I am slowing down, but throwing things out there. Maybe I will take video of my fuel system to show everyone. Maybe I did somethign wrong in the mix... #learning
The suction is just my intake...
Old 10-15-2012, 10:28 AM   #9
Wasted Income
Boosted Member
Key on / engine off should be ~ 55-62 psi
Engine running at idle with the vacuum line hooked up to the regulator should be ~52 psi
Engine running at idle without the vacuum line hooked up should be 58-60 psi.
No, you don't need the VSS hooked up for the engine to run correctly. I say this after personally completing and tuning several LS swaps on vehicles with manual transmissions, and vehicles with NO transmissions at all
Good luck.
Turbo diesel
Old 10-15-2012, 11:27 AM   #10
osaltyone
osaltyone's Avatar
Good luck.
Thanks, now I just have to figure out why I am not getting the pressure I should be out of the walboro pumps.
Old 10-15-2012, 11:38 AM   #11
Wasted Income
Boosted Member
I had a walbro pump take a crap on me...the truck wouldn't idle for crap...had to 2 foot it in traffic, etc.
Went to a Bosch 044 and never looked back.
Turbo diesel
Old 10-15-2012, 12:33 PM   #12
osaltyone
osaltyone's Avatar
This is my 2nd Walboro pump, seems odd that it would be 2 faulty pumps.
Is it possible I have an air pocket or something? I don't see how it is being restricted, other than the fuel has to travel over my step notch.
Fuel tank is in the rear, port on the bottom, so it has to be sucked up 9" or more from the rear port to the top of the notch.
Here are some pics during my build.
from the fuel pump it is hard line to the front, then the fuel filter, off the fuel filter fuel injeciton host up to the rail. That piece of hose is covered by 1" fire sleeve to protect it from exhaust, trans and engine heat.
Old 10-15-2012, 12:38 PM   #13
Wasted Income
Boosted Member
That is definitely not the ideal setup. Would be much better if you could have the pump PUSHING the fuel up over that notch, vs. it having to SUCK it out of the tank, and then up and over. That is also a lot of 90* bends...that also adds restriction to an already tough situation for that pump.
Turbo diesel
Old 10-15-2012, 04:04 PM   #14
osaltyone
osaltyone's Avatar
I don't see a way I can install the pump without sucking up from the bottom port to the frame at minimum. I'd have to see if I can fit the pump near the side of the tank.
Old 10-15-2012, 05:06 PM   #15
High ho silverado
High ho silverado's Avatar
That pump is above the tank pretty much, in my experiance with external pumps if they are not below the tank they air lock, and pulling them over the axle like that doesn't help, we had a holly black pump that would do it too, areomotive has a pump that claims to be able to pull and push no matter were u put it they also make a pretty slick intank unit that would deffinatly do the trick but its all in how much a guy is willing to spend, lol. I personally will never buy another walbro pump again, had lots of problems with them, jus my two cents. Hope u get it fixed, I hate to see a beautiful machine like that sitting in traffic.
Dan G
Lift it, fat chicks cant jump!
83 Chevy shortbed 4x4: 6.0 ls powered
97 Chevy 3/4 ton ex cab 454: work horse
00 Chevy camaro: daily driver
83 Chevy 3/4 ton: dads old rig
High ho silverado is offline   Reply With Quote
Old 10-15-2012, 07:49 PM   #16
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
mount that pump closer to the tank. here's my setup also with a walbro...vette reg is on the inside. may not be the ideal setup.....but its been feeding 500+hp LSx w/o issue.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-15-2012, 09:13 PM   #17
osaltyone
osaltyone's Avatar
Yea, I was trying to copy yours when I first saw it, but my airbag and cantilever setup runs all the way back along the outside frame. I might be able to mount it on the bottom of the frame in the area where your tank bolts through the frame. Looks like your tank is similar to mine.
Old 10-15-2012, 10:34 PM   #18
osaltyone
osaltyone's Avatar
As yo can see it is in the way.
But I was thinking about mounting it here with the feed fromt the tank toward the front of the truck, loop the feed to the rail around to the inside of the frame up to the notch. Do you think that will work? Wonder how everyone else with a step notch is doing it. I can remove the hard line over the notch, but did not like the rubber hose when I had it running there before.
Old 10-15-2012, 11:35 PM   #19
68GMCCustom
That's where I'd put it. there's a BIG difference between it being fed from there VS where you had it before. These pumps are designed to push...they don't pull so well.
Another choice would be drop the tank and mount and internal. Mine's a Boyd's tank. They do them in efi too....but my build was carb'd so when I bought I didn't get the efi option. Now I wish it were in the tank...but at least its easier to service this way!
Kurt -
Old 10-15-2012, 11:39 PM   #20
osaltyone
osaltyone's Avatar
I will try and see. Thanks! The tank is a Brothers tank, so I am not sure on my in tank options. It was like yours originally carb, until I got the itch to tear it apart and do the 5.3.
Old 10-15-2012, 11:54 PM   #21
awhite4557
awhite4557's Avatar
Another option is to mount an internal pump in your tank. Tanks Inc. sells one that might work, here is the link http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
This set up uses a walbro pump.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
