10-12-2012, 04:30 PM | #26 | |
Re: hard to fill with gas
What I end up doing is physically grabbing that vapor shield and pulling back the switch by hand, then I can feed the nozzle in as shallow as I wish, then it pumps just fine, but it's a pain. We don't have those here in Arizona. If you are overflowing while filling, it sounds to me as if the vent hose is either clogged, too small for the amount of fuel you are dumping, or the vent isn't mounted high enough on the filler neck vs how far you are shoving the nozzle in. |
10-12-2012, 11:44 PM | #27 |
78 Big10 454
I've been putting up with it for almost 35 years...
1978 Chevy SWB C-10 2WD 454/400 |
10-14-2012, 06:35 AM | #28 |
put a late model filler tube into it. we used a late 90s and put it into my moms old 76. she was gettin older and couldnt make the click and fill trick work. new nozzle/more flow/new technology
10-14-2012, 07:31 AM | #29 |
Is that because the tube has a larger diameter fill area or is it a larger venting tube?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-14-2012, 01:19 PM | #30 |
I would assume this L shape we have on the filler hoses isn't exactly the greatest for high flow pumps.
Motorcycles have this little cup riser they use so pumps with vapor collecting nozzles work in the small tanks. Maybe it will work for us? Btw gas is 4.13 here for 91ron e10. 4.22 for 91 ron pure gasoline this ethanol crap is starting to bug me. I can tell if my fuel is loaded with ethanol just by listening to it idle in gear. My tires know when it's real gas too Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
10-14-2012, 01:26 PM | #31 |
76 seems to be the only ethanol free gas i can find. not all of them. i only use 2 gas stations because of ethanol adn i dont have problems with those pumps
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
10-14-2012, 04:19 PM | #32 |
I get Safeway gas. It's either shell or bp fuel. The only two fuels there are
10-15-2012, 03:20 PM | #33 |
Same thing on my '77. It was a ***** to fill the tanks. Eventually, I learned to turn the nozzle upside-down, but even that was hit-n-miss.
Ended up swapping over to an 80+ bed with fuel doors rather than the cap mounted to the bed design. Haven't had an issue since. |
10-15-2012, 03:26 PM | #34 | |
Since I'm stuck in the vintage era, I couldn't bear to give up my large opening leaded filler necks on my 79 |
