Old 10-11-2003, 11:55 PM   #1
Scott Johnson
Junior Member
Scott Johnson's Avatar
Spot weld cutter
Just got a neat tool from Napa. It`s a spot weld cutter that really helps in removing those pesky spot welds when replacing panels. You have to watch it so you dont drill through the back piece of metal, but it has really saved me some time. The part # is 770-3841 if anyone is interested. Just thought I`d pass this along.
Scott
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 10-12-2003, 12:12 AM   #2
Dan72cst
Dan72cst's Avatar
Thanks, every time I drill all the way through and then have to weld up all the holes. I keep telling myself that I'm going to get one, but haven't yet.
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 10-12-2003, 08:20 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I bought some from a cheapy tool store in my area. These things work great! Everyone should have a few.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-12-2003, 01:57 PM   #4
Spoof
Spoof's Avatar
What is this wonderful tool of which you speak!
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 10-12-2003, 03:28 PM   #5
Gee_Emm
Basically a fancy drill bit. Are they really worth getting? I keep thinking I should get one.
Gee_Emm is offline   Reply With Quote
Old 10-12-2003, 04:47 PM   #6
RON WOODGEARD
Resident Young Old Dude !
It is a "specialty" drill bit, that has a relatively small bit at the tip of a bigger bit. The bigger bit is Flat, not angled.
It is designed for the small portion to go through both pieces of the spot weld, but the large part only goes through one piece of the two ( of the metal) Then when you re-use the part you needed, it gives you one solid piece to weld to.
I got mine from Piston.
Ron
RON WOODGEARD is offline   Reply With Quote
Old 10-12-2003, 08:28 PM   #7
Gordo
Thumbs up
I bought a set from Snap-On a while back. Blue-Point "Rotabroach Sheet Metal Cutters" Part# GA219B. Best thing since indoor plumbing.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 10-15-2003, 07:29 AM   #8
Scott Johnson
Junior Member
The NAPA tool sells for about $12 and is well worth the money in the amount of time it saves you.
Old 10-15-2003, 08:22 AM   #9
bobs409
bobs409's Avatar
hee hee, I paid $5.99 each! (but im a cheapskate)
These are Taiwan jobs but cut through those welds like butta'.
Bob
Old 10-15-2003, 08:22 AM   #10
BadAssChevy502
Yeh It's Fast
BadAssChevy502's Avatar
Thumbs up NAPA url
http://www.napaonline.com/cgi-bin/nc...2&prmenbr=5806
(I'm sorry if the spelling isn't correct,i'm trying the best I can )
1972 C20 3/4 Pickup Fleetside 502ci Th400
Click here to view pictures of my truck
1971 C20 3/4 Pickup Fleetside 350ci 3speed manual gearbox
"IF IT AIN'T BROKE DON'T TRY TO FIX IT"
Zwijndrecht,
The Netherlands
Europe
BadAssChevy502 is offline   Reply With Quote
Old 10-15-2003, 12:33 PM   #11
mrein3
mrein3's Avatar
I bought a cutter off the shelf at the local parts store. It looks just like the one in the napa link. The "cutter" is obviously reversable. My question is how do you reverse it?
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-15-2003, 03:48 PM   #12
crazy4chevs
crazy4chevs's Avatar
ive tried the ones like the napa one, it sucked. eastwood has some pro ones that look real good. http://www.eastwoodcompany.com/itemd...1.x=52&I1.y=63
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 10-16-2003, 09:03 AM   #13
bobs409
bobs409's Avatar
My Taiwan cutters are just like in the Napa link above. To reverse, you unscrew the black cutter part and turn it around. (notice cutting teeth on both ends)
Bob
Old 10-16-2003, 09:25 AM   #14
VTKidder
They need to spin clockwise to work.
jk....couldn't resist that one!
VTKidder is offline   Reply With Quote
Old 10-16-2003, 08:23 PM   #15
Scott Johnson
Junior Member
Saw the ones at Eastwood, looks like they would work well. I was just in a hurry and NAPA got the tool the next day. It has worked fine for me though. I just center punch the weld and start slowly and it rips right through the weld.
Old 10-17-2003, 12:31 AM   #16
sbrban
The drillbit from napa is called a blair cutter made by blair ind. they work good but be careful not to angle the bit while drilling, it will break and "walk" across the panel your'e working on. If you are drilling a lot of spot welds get the wivco"spot eze" brand bits like what eastwood sells they last alot longer and you can drill in closer areas. Of course you could just buy a spot weld drill and avoid all the effort-work excellent-a little testy though, mine was $500.
you never have too many suburbans....
sbrban is offline   Reply With Quote
Old 10-17-2003, 12:51 AM   #17
sbrban
here's the drill-it went down in price even!http://206.117.149.144/acb2/showdetl..._ID=30&CATID=3
