Old 10-15-2012, 04:12 AM   #1
mkharib
C20 1968 break problems
Hi guys , i need your help my C20 1968 long bed, am facing problem with the breaks and as you know its 8 lug I want to change it to 5 lug or 6 lug … and fix the breaks problem. So what do u advise me.
mkharib is offline   Reply With Quote
Old 10-15-2012, 07:59 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: C20 1968 break problems
Read, read, read.
There is a ton of info on here.
Also look at the Suspension Marketplace.
http://67-72chevytrucks.com/vboard/f...play.php?f=210
I would also look at ECE.
www.earlyclassic.com
Keith
Convert to disc brakes.
Old 10-17-2012, 03:46 AM   #3
bugmasta
bugmasta's Avatar
order the conversion spindles from earlyclassic.com then use standard components for a 72 c10. i know it works, i did it.
find a c10 rear end in a junkyard and swap the springs for c10. earlyclassic.com has a kit for this as well as it changes you panhard bar and relocates your shocks.
easy to do and can be done in your driveway. i know cause i did it.
bugmasta is offline   Reply With Quote
Old 10-17-2012, 04:37 AM   #4
SS Tim
SS Tim's Avatar
Don't think it is going to be that simple for him if the truck is at his listed location.
Rebuilding the stock brakes is generally the easiest and is factory documented in the service manuals.
SS Tim is offline   Reply With Quote
