Old 10-17-2003, 09:00 AM   #1
88Jimmy4x4
88Jimmy4x4's Avatar
Smile New to forum, need lift advice
Hello guys, I finally bought a 1988 GMC Jimmy 4x4 I have wanted one of these since I could drive. I have some 36x14.50x16 STS tires mtd on 16x10 AR wheels and I want to put them on my Jimmy with a lift. Problem is I dont want to much lift or too little lift. I was thinking 6", but these fenderwheels are so big I was wondering if a simple 4" would suffice. I have only had IFS lifts in the past so I really need some help and good advice on lift size, lift brand and anything else I will need or should do to run these tires and install this lift. Will d-shaft need to be lengthened etc?
Just fyi...I live in south Texas so theres no rocks to crawl, or alot of "flexy" situations. I plan on using this Jimmy for beach trips (wade fisherman) and camping...basically light offroading. This is my daily driver.
Thanks alot guys, any info will be greatly appreciated
JB
Heres a picture of my Jimmy just to show what were working on.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-17-2003, 04:07 PM   #2
Insanemadhatter
My friend had a 2" blocks in back and springs in front and he fit 33's. Now he has a 4" Lift springs all around with 35 BF's and they fit good. Just make sure that they aren't to wide or they will rub when you turn. Personally i putting a 4" on with 33's BF's
hope this helps
Insanemadhatter is offline   Reply With Quote
Old 10-17-2003, 04:17 PM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
Okay, well I guess I need a 6" lift then to be sure I dont rub.
Any specific brand or custom setup that anyone prefers?
I want to do this right the first time.
1991 GMC Jimmy 4x4
Old 10-17-2003, 04:28 PM   #4
Insanemadhatter
if you are to do it right. Use springs all over front and back do not use blocks. Superlift or ProComp are good but remember that a 6" lift may lift you up higher than that depending on the manufacturer. I would call them and ask before purchasing it. Also remember you will have to change your pitman arm. i dont know if that comes in the kit.
Old 10-19-2003, 01:30 AM   #5
alf4444
alf4444's Avatar
I have Tuff country 6" on mine and highly recommend any TC product, plan on extending your drivelines and getting extended brake lines and steering arm if you want to do it right. I agree with springs all the way around if you plan on wheeling it but if you don't blocks are fine plus 6" spring in the rear will effect ride quality.
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 10-20-2003, 07:10 AM   #6
Tink
Tink's Avatar
I really like the Skyjacker lifts... that is what I'm planning to get for my 76.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 10-20-2003, 06:55 PM   #7
Jonboy
Slots go on anything!
the 6" Pro Comp lift at 4Wheel Parts Wholesalers is a good and inexpensive lift. I have had one in an 86 Sub and a 75 K5, and have been very impressed. If you do go 6' in a Blazer/Jimmy, make sure you do the raised pitman arm, s-shaped drag link, and extended brake lines. I would also suggest using double shocks in the front, as it helped considerably on the Blazer. You will need to get the driveshafts lengthened as well, and it seems like I dropped the transfer case about 1/2 inch to ease the driveline angles a bit.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 10-24-2003, 09:44 PM   #8
88Jimmy4x4
88Jimmy4x4's Avatar
Thanks guys, well I ordered a rough country 6" full spring kit, raised steering arm, sway bar drops/bushings,extended SS brake lines, shocks and dual steering stabilizer. Got all this delivered to my door for $650
I priced out the same in skyjacker and it was $1200.....I just couldn't see paying double.
Im spending the money I saved on some HD front shackles and greasable bushings on all the springs. Also ordered the steering box brace (no cracks yet).
Thanks for all the advice....lift goes on Nov.1 :p
1991 GMC Jimmy 4x4
Old 11-02-2003, 11:04 PM   #9
mutant-jimbo
mutant-jimbo's Avatar
when do we get to see it? ive got a 4" tc lift, thinking of going another 1 with shackel flips...would like to see it
"Texas is an outrage when your husband is dead, Texas is an outrage when they pick up his head, Texas is the reason why the presidents dead"-bullet by The Misfits
mutant-jimbo is offline   Reply With Quote
