Old 10-17-2003, 09:54 AM   #1
67CHedges
Question 67 250 runs rough, backfires when shut down.
My 67 C-10 250 three on the tree is not running as smooth as it used to.
The symptoms are:
1). It seems like it is running on 5.5 or five cylinders. You can really tell when you are trying to pull a hill.
2). When I shut it down after it operates under normal operating temperature, it has a loud backfire.
We have recently converted the distributor to a HEI pointless ignition and replaced the carb a few months before that. The carb has never worked as well as the old one.
I have tried to troubleshoot and have done the following.
1). reset the timing several times.
2). verified the wiring, distributor and coil.
3). I checked the compression to see if I had a valve problem. The book I have says the compression is 130 psi. From front to back, starting with the first cylinder, I range from 125-150. Cylinders 2-6 are within 5-10 pounds. The first cylinder is about 20 off from the others. Don't know if that is contributing to the problem or not, but wanted to check it anyway.
I have not changed the plug wires, they are new, but I know that doesn't necessarily mean they are good. I checked the gap on the plugs when I checked the compression, they were all close, if not right on.
I am frustrated and wondered if anyone has some tips before I hand it over to a garage. I checked some of the archieves and didn't see anything that addressed my issue.
I am wondering if we have the distributor off a tooth? Or if the new carb is the culprit.
Thanks in advance.
1967 C-10 Custom, 250, 3 on the tree.
67CHedges is offline   Reply With Quote
Old 10-17-2003, 11:39 AM   #2
oldsub86
Did the troubles exist before you converted to HEI?
Did the troubles exist before you changed carbs?
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 10-17-2003, 12:12 PM   #3
67CHedges
It never has run as good with the replacement carb.
I am a little leary of replacing it since it would run me around $100. That is a pretty expensive guess. There is supposed to be a good carb guy in town I was thinking taking it to. We have tweaked on it to our ability.
The old distributor was wore out. It would backfire some when going down a hill. The cam was wore almost in a perfect circle.
I was hoping it was something simple. This was my Grandpa's old truck. He bought it new, and I got it after he died. He would never give it to me while he was living. It only has 105K miles on it.
Old 10-17-2003, 04:07 PM   #4
TP from Cntl PA
TP from Cntl PA's Avatar
Maybe you got a bad plug? I have gotten Champions(Well, my buddy bought them.........I always use AC's) for our Farmalls that were bad, and they were brand spanken new!
My brother's 69 C-10 did the same exact thing.........But the shmuck who sold us the truck had put the plug wires on wrong...............It is a 250 and it likes to back fire, but I have the timing more advanced than it should be...............But man, pulling 300 bu gravity wagons up mountains with a 250 and 3spd, with 3.73 gears it runs like man out the straight exhaust stack we have on it!!!!!!!!!!!!11
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 10-17-2003, 07:27 PM   #5
Denny
Denny's Avatar
It sounds like a timing problem to me. Might want to check if the distributor was put in at TDC for sure. Good luck.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 10-17-2003, 07:29 PM   #6
kroodawg
sounds like a timing problem to me also
1968 SWB CST
kroodawg is offline   Reply With Quote
Old 10-19-2003, 10:17 AM   #7
Blue Beard
Blue Beard's Avatar
Hope the plug wires are for the HEI.
And assuming that you eliminated the yellow wire from the old distributor to the starter when you converted.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-19-2003, 01:29 PM   #8
67CHedges
I am pretty sure the wires are the right type.
As far as the yellow wire to the starter, it is still there.
What does that do?
Old 10-19-2003, 01:33 PM   #9
Blue Beard
Blue Beard's Avatar
Disconnect the yellow wire from the starter...........its not needed.
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 10-28-2003, 03:30 PM   #10
67CHedges
Thumbs up
Thanks Bluebeard. That helped it some. It is running better after I removed that wire than it has in a long time. I don't know why, but it is.
I may get her back to normal after some more timing and carb tweaks. She may be back to purring like a kitten soon
Old 10-28-2003, 04:15 PM   #11
CPNEJR
CPNEJR's Avatar
I know my 67 backfired because the carb was junk. as for the rest I have no clue
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 10-28-2003, 04:27 PM   #12
67CHedges
It is a prime suspect.
The truck has only had 3 carbs in its lifetime. The original was not as good as the second. The second was the best carb I ever had. I had to replace it with the one I have on it now. It is a rebuilt model, like the second, but has never performed well, in my opinion. I hate to guess, pull it off, and replace it with another near $100 dollard rebuild. Unfortunately it is not like the old days when I had these things laying around everywhere and changed them out once a week (or weekend ) O 4 the good ol days
Old 10-28-2003, 06:13 PM   #13
69C10Atl
Trying to stick with it
69C10Atl's Avatar
How long ago did you change the HEI. If i'm not mistaken the position of #1 on a HEI is different than a point type distributor. At least it is on a V8.
69 Chevy C10 LWB somewhere in the pile of parts in my garage.
01 Cadillac STS as daily driver
69C10Atl is offline   Reply With Quote
Old 10-29-2003, 09:47 AM   #14
67CHedges
2-3 months ago, maybe longer. I don't drive it too much, maybe once or twice a week, especially since it is not running as good as it has been, and drinking extra gas.
Where can I find the firing order, if it is different than the stock distributor?
Maybe I misidentified the distributor. The one I used was out of a 70 Nova 6 cylinder. It has an external coil, but no points. I was told that is what it was, but maybe that is not what it is.
Old 10-29-2003, 02:05 PM   #15
69C10Atl
69C10Atl's Avatar
I'm not sure of the firing order for a 6cyl with an hei, but on a V8 the firing order is the same but the position for the #1 spark plug wire on the distributor moves over one plug clockwise. I found that out the hard way, just rebuilt Holley four barrel and rebuilt HEI, fired up truck it ran rough then backfired through carb blowing out my power valve. Once I found out the Hei is a little different I was so mad. Never did fix the Holley, just replaced it.
Old 10-29-2003, 02:37 PM   #16
67CHedges
That would explain why it seems like it is running on 5 or 5.5 cylinders. I think we have it timed right. We used a light and used the settings indicated in my manual.
It does run better after I removed the yellow wire from the coil, but still is missing something.
I would figure it would run pretty nasty if the wires are one out or order.
Has anyone else had experience with this? Firing order that is.
