Old 10-16-2012, 02:36 AM   #1
Touchdown67
Touchdown67's Avatar
Rear end gear forum?
I have a 65 c10 with a 12 bolt rear end, what is the best way to determine what gear ratio it has? The rear end is making a little noise. It has a SB400 with a 700r4 transmission with 275/75/15 radial tires. Would it be good to consider 373 gears?
Touchdown67 is offline   Reply With Quote
Old 10-16-2012, 08:14 AM   #2
m455sx
m455sx's Avatar
Re: Rear end gear forum?
perfect choice
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 10-16-2012, 09:02 AM   #3
'65Burb
What usually came stock?
'65Burb is offline   Reply With Quote
Old 10-16-2012, 09:04 AM   #4
m455sx
m455sx's Avatar
I think 373's
1970 Cutlass SX
1962 Chevy Stepside
Old 10-16-2012, 02:04 PM   #5
luvbowties
luvbowties's Avatar
Thumbs up Re: Rear end gear forum?
Here's a good explanation to help determine ratio. Add to it: "just over 3 revs=3.08; 3 1/4 revs =3.23; 3 1/2 revs=3.55; 3 3/4 revs=3.73; a tad over 4 revs=4.11; 4 1/2 revs=4.56; ...etc."
>> http://www.ehow.com/how_12156231_cal...ear-wheel.html <<
I presently have a 3.73:1 gear, 5.7 Vortec about stock w/headers & 4 bbl, 700R4, and 275-70-15(?..or 265-70-15?) in my '66. I'd say it performs about flawlessly. In overdrive, the 70% reduction of the 700R4 gives (3.73X.70) a 2.61 final drive for hwy cruising. Plus, that extra-low 1st gear provides about all the launch you can get away with around town with so much traffic and so many lawmen.
HTH. sam
luvbowties is offline   Reply With Quote
Old 10-17-2012, 12:12 AM   #6
Captainfab
60-66 Nut
I just don't understand why no one is willing to just remove the rear cover and have a look. More than likely the oil needs changed. It'll only cost a couple quarts of gear oil, a cover gasket and a little time. Then you'll know exactly what you have inside your differential, and it will have gotten an oil change.
