#51 |
Re: Crewsin in my 63 GMC Crew Cab
Sounds good. Im still keeping my eyes peeled for one myself. Im in no time rush though due to my current projects and budget
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#52 | |
Rollin' Old Skool
I remember seeing pics posted of this thing a good while back but didn't realize someone had purchased it...can't wait to see the progress, & I feel like it's in good hands with Tony....good luck with everything!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#53 | |
The 60-66 GMC/Pontiac guy....
Just sayin..........
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#54 | |
I'd chew my truck up bite by bite and poop a hundai for that kind of money. I'm sure the work would be great, but it sure makes ya squinch up a little in the tail end. ![]()
Step by steps: Remove primer to reveal original paint Rebuild a carburetor See My Build - Cecilia! ![]() Some people are like slinkys. Not worth much but funny as heck when pushed down stairs. |
#55 | |
Rollin' Old Skool
#56 | |
I replaced the entire floor, rockers (inner and outer) and cab corners in a truck for a guy took the cab to have it media blasted and sealed it in and out for less than 10% of your 20K budget. I understand that much of a crewcab floor structure needs to be fabricated. After all, crewcabs were not factory built anyway so it should be expected. The cost of quality paint is outrageous now so I understand. My best friends 66 gto came to over $30K when all was said and done and that was a rotisserie build, frame off, no expense spared. My advice would be to have the structural completed on the cab and tackle the chassis and drive train yourself. It is easy enough that a kid could do it... These trucks are 100% easier than doing a frame off car project IMHO.. ![]() ![]()
#57 |
My previous post is not a judgement of or about anyone.
I have witnessed many would be car and truck builds gone wrong and well meaning builders and owners projects going sideways... My comment about greed and inexperienced owners was a general statement and not directed at any specific individual. My point is that when someone has a shop or builder do a project, that someone needs to do extensive research and get more than 1 bid on the project. Just sayin.... ![]()
#58 |
60-66 Nut
All the work I have seen Tony do is top quality for sure. Doing a quality job takes more time that doing a not so nice job, and time is money. And that's not to mention the cost of parts and materials.
#59 |
Location: I live in Honolulu but my truck is being restored by 4-5-6 Trucks in Kansas City
I'm in a unique situation. It was very hard for me to find someone to do this restoration. I had a couple of people suggested to me when the truck was in Washington State, but the bottom line is I felt most comfortable with Tony. Remember--I'm in Hawaii and can't really haul this thing around getting bids. In fact, I've never even seen this truck in person. If I'm going to bring this truck to Hawaii, I have to be 100% certain it's done correctly or it won't last 5 years here.
On that note--Tony does have a reluctance about cutting up donor trucks. I almost wish he didn't, because I think it might be cheaper to cut up a donor cab/bed than to do all the fabrication work. Then again, when it comes to body work I'm completely talking out of my ass. That's why I want to get (at a minimum) all the rust repaired. It'll take longer, but I'd like to think I can take care of the rest. ![]() Posted via Mobile Device
1963 GMC Crew Cab: Crewser Picture album pre-restoration: here Tony's picture album (4-5-6 Chevy Trucks, where it's being restored): Here Last edited by cetacean6; 10-18-2012 at 02:14 AM. |
#60 |
1961 crewcab
his reluctance might be that even though a donor looks real good , it would still need to be gone through. I have seen pics of one tony did, "rust free", and it was , looked real nice, problem is is that gm did not prep the inside of any metal in 60-66, this truck tony had, needed a rocker replaced because of a hole from a forklift... when he got the "rust free" rocker off , it was all scaly and surface rusty on the inside, all our trucks look like this to some extent when cut apart.
to get your truck to last in hawaii, I would look into sealing it up as much as possible , and if there is any way to "dip" it in primer, I would look into that. that said if tony uses new coated patch panels , and lots of weld through primer, you should have a good head start on keeping it nice. I would say that you have a unique situation with trying to keep it nice in a tropical climate. we sent my sisters 78 camaro with her to hawaii,and after 3 years the nice dry camaro was a piece of junk, rusted through the roof, and other places (she had no garage).
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#61 |
As I said, I wasn't saying anything about anyone specific. I don't know Tony and haven't seen his work.
I was only saying what I tell anyone who comes to me for work. Get informed on your project as best you can and get different bids. If you are in Hawaii and the truck is stateside you have a marked disadvantage. These trucks have inherent weaknesses.. bottom rear fenders rust, cab corners and rockers, etc.. You can take precautions to minimize and eliminate much but the bottom line is maintenance and care after the truck is done. My suggestion of getting structural and chassis done and finishing up the rest yourself was because of your budget. 20K won't finish that truck. The motor (V6) will be a quarter of that budget at least, if you do it correctly. Parts for that old beast (the V6) are expensive. Of course you could go the Chevy V8 route but thats not what the truck came with so it isn't a restoration at that point. I understand why someone wouldn't want to butcher a donor too. GMC trucks are getting rare and chopping one up is something I wouldn't do either. I have several Chevy cabs and parts for donor sheet metal. I love your build, wish I had one too.. (the crew cab) Cap Fab and Jon are right.. it takes time to do structural rework especially on a rare bird like you have.. I only caution people because of what I have seen in the 3+ decades of building cars and trucks.. Sounds like Tony has a good rep.. that is a good starting point for a build.. Good luck
#62 |
Tony should be tearing down the crew cab very soon. Keep an eye out for pictures on his Flickr page (link in my signature). Woo-Hoo!
#63 |
Whoah! What happened to all my pictures? I had them on webshots, but I guess they must have deleted them all? That sucks!
I've downloaded all the pictures onto Flickr and put links to them instead of having them all here. Hopefully everyone can still see them.
1963 GMC Crew Cab: Crewser Picture album pre-restoration: here Tony's picture album (4-5-6 Chevy Trucks, where it's being restored): Here Last edited by cetacean6; 01-11-2013 at 12:47 AM. |
#64 |
I have the same truck for the most part only mine was in much worse shape, If the truck wasnt so rare I wouldnt have even messed with trying to bring it back but these crew cabs are rare. I feel you on the money it takes to bring it back to life. Im real close to finishing mine now 6 weeks I will have it on the road.
I had to replace fenders, front, hood, door skins, front half of the roof, the one thing that was real good was the cab floors, only rust i ran into was about 8" into the drivers side floor the rest was perfect. Good luck on your project. |
#65 |
Still waiting....Things were supposed to start back in January, but it's June and I haven't seen any updates from Tony. He's not answering my e-mails...
1963 GMC Crew Cab: Crewser Picture album pre-restoration: here Tony's picture album (4-5-6 Chevy Trucks, where it's being restored): Here Last edited by cetacean6; 06-03-2013 at 07:53 PM. |
#66 |
#67 |
Subscibing...... love to see some updates as they come.
#68 | |
There is a reason he was banned from this site.... I hope everything works out for you. I gotta get me a crew one of these days!!! Posted via Mobile Device
#69 |
Man, that's a nice truck....a crew cab would be awesome to find around here
1963 Chevy C10 (under construction).....build thread 2009 Honda Shadow 2008 Mazda 5 2013 Ford Sedan Interceptor AWD 2017 Harbor Freight 4x8 trailer (great for hauling parts) 2017 Honda Rebel |
#70 |
#71 |
Rollin' Old Skool
Yay for you! So Tony still has it?
#72 |
Glad the issue was resolved on where the truck was. Nice to see the build underway and I'm sure Tony will do a top notch job like he does on all his projects.
Bet that rear floormat is a tough item to find. Nice to see its still in there.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 09-26-2014 at 03:15 PM. |
#73 |
![]() Join Date: Feb 2013
Thumbs up, glad it was saved.
![]() 1961 Apache 10 with side trim 1964 4 door crew cab C20 1966 Chevy Suburban with custom trim 1961 K30 with a 4-53T Detroit diesel 1966 GMC 4X4 Suburban |
#74 |
chevy only
![]() Join Date: Sep 2006
nnnice let the fun begin!
CHEVY ONLY... Nothin Else ! |
#75 |
![]() Join Date: May 2007
sweet
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
